Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?
Old 17th September 2019, 06:33 AM   #3071
Ro808 is offline Ro808  Netherlands
Old 17th September 2019, 06:45 AM   #3072
cdm is offline cdm
Originally Posted by Ro808 View Post
Woofer is indeed TAD 1601, Horn is JBL 2386a and the 2" compression driver is a Sony SUP T-11, at least in the original version.
Thank you very much, Ro808. You´re better than Wikipedia! Do you happen to know (heard) the Strauss? And if yes, is this a sound, that camplo should seek for his endeavour?
Old 17th September 2019, 07:10 AM   #3073
docali is offline docali  Germany
docali's Avatar
@whg and @mabat probably talk of different things?
If we look at the situation of water in a rotating glass then we have the boundary potential of a cylinder like this:
M-60 | Zentripetalkraft: Rotiere... | Vorlesungssammlung Physik
We can see that the water will run over out of the glass at a certain rotational speed and a paraboloid is formed. So, it does not approach a cylinder. But if the potential is infinite (a glass with infinite height, the whole fluid approaches a cylinder for infinite rotational speed. But then we do not have a "simple" paraboloid equation anymore.
The best thing would be that you agree to echother of having talked about different things
Old 17th September 2019, 07:28 AM   #3074
mabat is offline mabat  Czech Republic
mabat's Avatar
Ro808
Please bear in mind how all these curves (i.e. circle, ellipse, parabola, hyperbola) originate. They are not called "conic sections" for nothing: Conic section - Wikipedia
Old 17th September 2019, 07:39 AM   #3075
GM is offline GM  United States
GM's Avatar
Finally! Something that gives me a clue what this sub-thread is all about! Thanks!
Sheesh! Ya'll had me feeling dumber than a box of rocks.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 17th September 2019, 08:14 AM   #3076
David McBean is offline David McBean  Australia
Originally Posted by mabat View Post
That is the definition of "approaching" to something, it must converge in total. The limit of the rate of change itself is not enough.
As in the attached simple example, which plots the expression y = x / (1 + x). The value of y approaches the asymptotic limit of 1 as x is increased, and y can never exceed 1.
A parabolic curve does not exhibit this limiting behaviour.
www.hornresp.net
Old 17th September 2019, 08:27 AM   #3077
mabat's Avatar
David, as you may have read, "What becomes limited is slope, and radius of curvature. So, the limit on y criteria, is a bogus argument against the cylindrical limit claim." - You have to be better than that
Old 17th September 2019, 08:30 AM   #3078
GM
It has indeed morphed into a very interesting philosophical discussion.
I am now somewhat regretting having innocently raised the subject of parabolic horns in the first place... :-).
www.hornresp.net
Old 17th September 2019, 08:38 AM   #3079
I give up - I have run out of ideas :-).
Besides, I think that we have probably just about beaten the subject to death by now. I am starting to feel quite sorry for all those genuine cylindrical parabolas out there...
www.hornresp.net
Old 17th September 2019, 09:34 AM   #3080
whgeiger is offline whgeiger  United States
Default Cheers!
Actualy, no. For a cone the area grows much faster, with the square of distance. This is really the parabolic expansion
You guys are addressing the obvious increase in y but do not want to address the unintuitive fact that slope and curvature are approaching zero in the limit for a paraboloid. Anyway, we are leaving the casino now, $13,800 richer than when we came. So despite the unpleasant experience I have had here, I can say goodbye with a smile on my face, anyway. WHG
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?Hide this!Advertise here!
cascode distortion Spectrum. mashaffer Tubes / Valves 34 22nd January 2017 09:37 PM
6av5ga distortion spectrum enzoastro Tubes / Valves 14 30th January 2013 06:01 PM
Distortion spectrum vs feedback artosalo Tubes / Valves 62 7th December 2011 11:51 PM
What do you look for in the distortion spectrum? keantoken Solid State 13 13th May 2009 12:06 AM
Tailoring distortion spectrum syl Solid State 14 25th March 2002 07:32 PM
Copyright ©1999-2019 diyAudio
