Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?
Old 12th September 2019, 05:33 PM   #2951
gedlee is offline gedlee  United States
gedlee's Avatar
Originally Posted by phase_accurate View Post
There is something of which I am still unsure what is causing it: Where does the waistbanding effect of waveguides and horns come from ? Is it caused by a ring-shaped (or whatever the mouth shape of the device is) virtual secondary sound-source caused by diffraction at the mouth ?
Charles
That's correct.
Earl Geddes Gedlee Website
Old 12th September 2019, 05:36 PM   #2952
gedlee's Avatar
Originally Posted by silverprout View Post
The old classics are much better (TAD, ALTEC, JBL...)
It is hard to beat the highly refined capabilities of the classic 15" woofer designs. It has withstood the test-of-time and come through with flying colors. To me, the 15" is the sweat spot for a great loudspeaker. The 18's just don't seem to be as good in general, and 12s don't have enough directivity for a good polar match to a high DI waveguide.
Old 12th September 2019, 05:49 PM   #2953
Ro808 is offline Ro808  Netherlands
A proper roundover would largely mitigate, or eliminate the waistbanding, I assume?
Old 12th September 2019, 06:29 PM   #2954
silverprout is online now silverprout  France
silverprout's Avatar
It is a very unusual application but it should help a little i think.
Blue 24in 100Gr paper straight cone 60° free air dipole at 30cm
Red 24in 200Gr paper straight cone 60° free air dipole at 30cm
PS : REW traces colors are beautifull
Things I Should Have Learned In School (But Probably Didn't)
Old 12th September 2019, 07:18 PM   #2955
whgeiger is offline whgeiger  United States
Default Potpourii
Originally Posted by mabat View Post
If you intended just that, then I don't understand why you called it an inflection point.
Early morning errant word choice. So what?
Curvatures of both segments will match at this junction, i.e. it should be smooth enough. There's no need to go for splines as I have it already working as it is. Is it possible to do it a bit differently? Of course it is. Will it be any noticeably better? Please show me that.
Using an unifying, but flexible fairness curve, should expand the investigatory domain and reduce design iteration cycle times. Will this methodology deliver an optimized acoustic horn design? As demonstrated by the article provided earlier, the answer to this question is a most likely yes.
- It was year 2013. So where are all the waveguides terminated by Euler spiral segment?
I am not in the horn design and manufacturing business at the moment. If I were, you would see a lot of C-Bézier horns in the marketplace and details concerning the design methodology used, would remain undisclosed.
WHG
Old 12th September 2019, 07:42 PM   #2956
Agreed.
>snip<
This is true, but I am unclear why it is beneficial. Below a modes cutoff this diffractions does not propagate, but above any modes cutin, this internal diffraction becomes a Higher order mode which does propagate. HOMs are not beneficial.
The benefit is provided by the curvature decline. WHG
Old 12th September 2019, 07:47 PM   #2957
gedlee's Avatar
Sorry Bill, I don't follow what you mean.
Old 12th September 2019, 07:50 PM   #2958
24" with 100g cone, must be a vintage driver?
The 200g cone is the same driver with added mass?
Old 12th September 2019, 08:11 PM   #2959
mabat is offline mabat  Czech Republic
mabat's Avatar
I woudn't say I share your conclusion. In the paper you referenced they optimized for two fixed control points on the contour. How would you know if the optimum found is a global one, no matter where and how many points you would choose? It's actually still quite limited result and in principle will allways be - it would take a heck of a time to go through all possibilities.
The most time consuming part is the actual simulation run, not the way how you get the contours under test. I'm quite willing to incorporate an import function of an arbitrary countour curve (as a text file) to my program that generates a BEM project that can be run on a readily available freeware simulator. Anyone could easily test their favourite profile. That would be a nice contest...
That's quite a bold statement.
Old 12th September 2019, 08:18 PM   #2960
Compared to other horns, OS horns have a throat profile of declining curvature, the rest have increasing curvature throughout their length; or none at all, as in the case of the (asymptotic) conical horn. Other means of wave spreading include sharp diffraction edges, 'speed bumps' (JBL), and dispersive acoustic lenses and reflectors which produce all sorts of (non-beneficial) response anomalies. WHG
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?Hide this!Advertise here!
cascode distortion Spectrum. mashaffer Tubes / Valves 34 22nd January 2017 09:37 PM
6av5ga distortion spectrum enzoastro Tubes / Valves 14 30th January 2013 06:01 PM
Distortion spectrum vs feedback artosalo Tubes / Valves 62 7th December 2011 11:51 PM
What do you look for in the distortion spectrum? keantoken Solid State 13 13th May 2009 12:06 AM
Tailoring distortion spectrum syl Solid State 14 25th March 2002 07:32 PM
Copyright ©1999-2019 diyAudio
