Is it possible to cover the whole spectrum, high SPL, low distortion with a 2-way?
Those are for live sound and part of a multi channel horn setup on stage in front of 5000 people or more. Crossover point is therefore rather high, I believe somewhere between 800 and 1000Hz.
The big 18 kW bass horn is loaded by 6 x liquid cooled JBL 2267 with custom (made by Miller Instruments) carbon diaphragms and includes an optical diaphragm displacement sensor.
This seems to be a more sensible approach to manifolding multiple drivers.
  • US20160366510A1_Manifold for multiple compression drivers with a single point source exit, Dougl.pdf
Not as sensible as Bruce Howze's 1981 approach, later adopted in the MTH-4.5/42B after EV's engineers realized the combining the output of too many drivers through a small throat does not work very well.
That said, for a two-way design of the SPL required by the OP, multiple HF drivers are not required anyway.
Art
  • Bruce Howze:Whelen Engineering.png
  • MTH-4.5:42B.png
Try this guy, he will do as much or as little as you want and has a local source for baltic birch plywood. Shipping isn't that bad..
Custom Speaker Designs and Kits | Speaker Hardware
I got a really reasonable quote from him on one project but aborted in favor of a local CNC shop that charged me twice as much. If all you really want is the sheets of ply cut down to size, the supplier should be able to do that.
Ah, you've found it ;)
The dbra_jmlc polars look good/usable, provided they do not turn into a laser beam > 8k.
Considering your objectives and the room, some (but not excessive) narrowing may even be beneficial, as it eliminates the need for excessive eq. in the top octave, amongst other things.
The sophisticated phase plug of the Axi2050 might also help (a little) to reduce narrowing.
