Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?
Old 11th September 2019, 12:56 PM   #2881
Ro808 is online now Ro808  Netherlands
It's a statement against the youngsters' addiction to screens, yes.
I am not exactly young... but still feeling like a 16 year old sometimes
One shouldn't kill one's inner child.
Old 11th September 2019, 12:57 PM   #2882
Dave Zan is offline Dave Zan  Australia
Originally Posted by Ro808 View Post
You'll be surprised
Possibly, but Marcel did some sims of a horn made of flat slices, to see if the work to blend them was really necessary.
The results looked "sub-optimal", to be polite.
But maybe not much effect in this case.
Originally Posted by mabat View Post
...to add radius as an option...Then it will be easily possibe. I'm curious as well.
That will be informative, thanks once more.
I suppose if the horn is built from flat slices then the slices are cut essentially the same so the only extra work is just a bit of calculation.
It just seemed more work to think about.
Best wishes
David
Old 11th September 2019, 01:51 PM   #2883
AllenB is offline AllenB  Australia
LeCleach has been mentioned too. Not my personal preference to terminate a waveguide, in theory it could be quite different to a radius.
Old 11th September 2019, 01:55 PM   #2884
mountainman bob is offline mountainman bob  United States
mountainman bob's Avatar
Originally Posted by GM View Post
Actually, just remembered someone made some nice drawings [auto download]: http://forums.melaudia.net/attachment.php?aid=6487
Good thing as they were pretty rare even before the bulk of them were scrapped.
GM
Awesome.....thanks!
So what do they call that mouth configuration?
Old 11th September 2019, 03:19 PM   #2885
GM is offline GM  United States
GM's Avatar
Technically it's a truncated front loaded horn [FLH], i.e. a 'slice'/section out of a full size 'x' Hz horn.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 11th September 2019, 03:24 PM   #2886
scott17 is offline scott17
GM
This cabinet is designed for the 604E?
I'm using mine now in 9 cu. ft. Stonehenge cabinets.
Old 11th September 2019, 03:30 PM   #2887
GM's Avatar
What was once old is yet new again. Altec had a mid range horn like this in its 9862 studio monitors: Altec Lansing 9862 - Great Plains Audio
GM
Old 11th September 2019, 03:40 PM   #2888
GM's Avatar
No, for the original 605, which would have been driven with a matching impedance amp with variable DF tone controls: 1945 DUPLEX
Your 'E' will need similar EQ to 'fill up' the 110.
GM
Old 11th September 2019, 03:45 PM   #2889
GM
Thank you.
I suppose if I was to undertake a project like that I might as well just go for the A5 system.
Old 11th September 2019, 04:18 PM   #2890
whgeiger is offline whgeiger  United States
Default Curvature
In the following drawing it's only about 1/5 of hyperbola, the rest is clothoid. In the rendering in will be a bit more.
>snip<
1) At the point of inflection the radius of curvature of both curves should match.
2) You can implement this profile, and others as well, with a single fairness curve. [1]
3) Check out the profiles generated by shape optimization regimens. [2]
4) The declining curvature in the throat, gently spreads a higher pressure wave front.
The increasing curvature at the month mitigates lower pressure wave reflectance.
WHG
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?Hide this!Advertise here!
cascode distortion Spectrum. mashaffer Tubes / Valves 34 22nd January 2017 10:37 PM
6av5ga distortion spectrum enzoastro Tubes / Valves 14 30th January 2013 07:01 PM
Distortion spectrum vs feedback artosalo Tubes / Valves 62 8th December 2011 12:51 AM
What do you look for in the distortion spectrum? keantoken Solid State 13 13th May 2009 01:06 AM
Tailoring distortion spectrum syl Solid State 14 25th March 2002 08:32 PM
Copyright ©1999-2019 diyAudio
