Is it possible to cover the whole spectrum, high SPL, low distortion with a 2-way?
Here's a sample of my Carver Amazing Platinum Mark IV dipole ribbon/woofer speakers. My kitchen/dining/living room is untreated, with windows covering most of the two outside (18' wide) walls. The ceiling is a peaked 12' blueboard with plaster, and the floor has burbur carpet.
The FR seemed to be least affected by the sidewalls and furniture at a distance of 2' from the ribbon tweeter. I EQ'd via REW and remeasured at this sweet spot.
The noise floor is very high in the <20 Hz area, and may contribute to the high distortion there. Also, the dipole woofers fall off at the expected rate after 30 Hz.
To me, that's ugly as hell, but... beauty is in the eye of the beholder, so what do I know? :)
It certainly won't win design awards, but the same is true for most large format (studio) monitors. And let's be honest: appearance is often a poor indicator of technical qualities. I have yet to meet the first person who melts away just by staring at a pair of Danley SH50s.
frugal-phile™
Joined 2001
No. You are specifying a web page not a picture.
dave :cop:
diyAudio moderation team
A special thank you to Don K and Docali...the most unique part of my journey would not of been so, if it had not been for their generosity. I can attest that they are dedicated to represent their talents to the fullest, even at leisure. A great quality!
attachment.php
Cheers
It does at least seem to be built to a high standard with which I could never compete.
The same loudspeaker - albeit with radial horn this time - next to his slightly bigger brother, and other 2 way systems from the same manufacturer.
