Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?
Old 18th April 2019, 04:37 AM   #261
GM is offline GM  United States
GM's Avatar
Originally Posted by camplo View Post
Thanks for that Gm
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 22nd April 2019, 05:53 AM   #262
camplo is offline camplo
Currently looking at the SEOS-24 and the Tractrix 350hz...any advice on what might better suit my needs for near field and/or studio reference monitoring
Old 25th April 2019, 03:00 AM   #263
Bump
Old 25th April 2019, 05:30 AM   #264
Omholt is offline Omholt  Norway
Omholt's Avatar
2384 is ok but due to its small size it looses the directivity quite early. I have the polars but I don't think I'm allowed to share them. A larger well built horn is in another league, but also takes up more space and will cost more.
Combining it with a 15" in a vented box (preferably 140 L or bigger) works really well and blows away any "high-end" commercially speaker out there IMO.
Old 25th April 2019, 05:38 AM   #265
pk is offline pk  Denmark
Hi Omholt,
Great looking new horn! How far down in frequency does the horn load, and what driver are you using?
Thanks!
Best regards
Peter
Old 25th April 2019, 05:42 AM   #266
Omholt's Avatar
Originally Posted by pk View Post
Hi Omholt,
Thanks!
Best regards
Peter
The horn to the left is Klipsck K402 which I assume you're familiar with. The horn on the right side is a prototype I have and working on. It loads down to about 300 Hz. I'm testing with both Radian 951, JBL 2450SL and other drivers.
Old 25th April 2019, 06:01 AM   #267
Thanks! How does the new horn compare to the Klipsch?
Best regards
Peter
Old 25th April 2019, 06:21 AM   #268
Omholt's Avatar
Best regards
Peter
Too early to draw any conclusions and I'm waiting for a new pair with better build quality. So far though, my impression is that it's a few steps above the K402 even when comparing with a low cost diaphragm to a beryllium in the K402. The horn is really more important than the driver/diaphragm.
Old 25th April 2019, 07:14 AM   #269
Hi again Omholt,
Thanks for the reply! That sounds really interesting. Where do you cross over to the woofer, and what 15" are you using?
Best regards
Peter
Old 25th April 2019, 07:24 AM   #270
Omholt's Avatar
Hi again Omholt,
Best regards
Peter
Around 600 Hz with this horn. I can cross over lower with another horn that I'll also will test. But 500-600 Hz area seems to be basically the lowest you can go with most beryllium 4" compression drivers. Perhaps somewhat lower with a very steep filter.
It's not important what 15" driver I'm using. I trying a lot of things. The final setup will by the way be with a midbass horn as the picture below shows (a 3-way system). I'm simply using a vented woofer as well for test purposes. But if you want a recommendation for a quality 15" woofer with high sensitivity I would recommend a driver from Acoustic Elegance.
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?Hide this!Advertise here!
cascode distortion Spectrum. mashaffer Tubes / Valves 34 22nd January 2017 09:37 PM
6av5ga distortion spectrum enzoastro Tubes / Valves 14 30th January 2013 06:01 PM
Distortion spectrum vs feedback artosalo Tubes / Valves 62 7th December 2011 11:51 PM
What do you look for in the distortion spectrum? keantoken Solid State 13 13th May 2009 12:06 AM
Tailoring distortion spectrum syl Solid State 14 25th March 2002 07:32 PM
Copyright ©1999-2019 diyAudio
