Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?
Old 14th August 2019, 08:15 AM   #2031
silverprout is offline silverprout  France
silverprout's Avatar
Originally Posted by Ro808 View Post
Probably to narrow the beam (further) to increase output and reduce phase and other interference issues.
This horn was designed in order to cover the vocal range in stacked setups with BMS 4590 or 4592 coaxial.
Thanks for the information, IMHO high directivity horns are low-fi devices but unavoidable when a high directivity is required on a large frequency range.
Things I Should Have Learned In School (But Probably Didn't)
Old 14th August 2019, 12:23 PM   #2032
Ro808 is offline Ro808  Netherlands
Originally Posted by 4real View Post
One related question to the experts: how is the function of the diffraction slot influenced by making the horn longer with the adapter?
This is a very good question.
AFAIK the inner workings of diffraction slots are very hard to desribe mathematically. IOW it's difficult to 'predict' the wavefront inside and after the slot at one particular frequency, let alone across the band.
Read Kolbreks thesis on 'mode matching' to find out. He couldn't really get passed the 'pinched throat' case, which is just one feature of some slotted horns. Modern diffraction slots are developed by use of computational techniques (FEA etc.).
I am looking forward to Dr. Geddes' reply, even though I am perfectly aware he 'doesn't like diffraction slots', to put it mildly.
Diffraction slots have their merits and they can work very well, if implemented with care. Earlier in this thread some examples were cited.
Here's another:
Old 14th August 2019, 01:56 PM   #2033
Obviously: "Bjørn Kolbrek couldn't get past the pinched throat case"
I also referred to the wrong thesis: "Extensions to the Mode Matching Method for Horn Loudspeaker Simulation".
The pinched throat is dealt with in his Master's thesis: "Modal sound propagation in curved horns of rectangular cross-section".
Old 14th August 2019, 02:10 PM   #2034
plasnu is offline plasnu  United States
Dr. Keele's study is a good reference for MTM crossover design. Can’t find Part 2...
https://www.xlrtechs.com/dbkeele.com...20Part%201.pdf
Old 14th August 2019, 02:13 PM   #2035
tuyen is online now tuyen  Australia
Send a message via MSN to tuyen
https://oceanwayaudio.com/display/wp...et_0119_LR.pdf
I’m assuming a good sounding implementation of ‘2-way’ MTM design with 2 15” woofers and a 1” HF Cd (assuming TAD200x) paired with a 100x40’ horn.
Old 14th August 2019, 02:15 PM   #2036
Hey, This is a copy of JBL S9500, which is a copy of Kinoshita.
Old 14th August 2019, 02:18 PM   #2037
Seriously, this kind of large WTW is somewhat problematic in a room where the ceiling is untreated and/or low.
Old 14th August 2019, 02:23 PM   #2038
This is the presentation of the paper.
This is the actual paper.
Old 14th August 2019, 02:34 PM   #2039
Great!
BTW, I was applying linear phase for WTW for years, but now, 18dB minimal phase. Different sounding approach, and I can't say which is better...
Old 14th August 2019, 02:47 PM   #2040
Not sure if posted yet, but this info about the JBL K2 project has same objectives as topic.
Some interesting info I found. 650hz crossover. 2nd order. Check the manuals of the various models
AllegroSound * JBL Project K2 S9500 *
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?Hide this!Advertise here!
cascode distortion Spectrum. mashaffer Tubes / Valves 34 22nd January 2017 09:37 PM
6av5ga distortion spectrum enzoastro Tubes / Valves 14 30th January 2013 06:01 PM
Distortion spectrum vs feedback artosalo Tubes / Valves 62 7th December 2011 11:51 PM
What do you look for in the distortion spectrum? keantoken Solid State 13 13th May 2009 12:06 AM
Tailoring distortion spectrum syl Solid State 14 25th March 2002 07:32 PM
Copyright ©1999-2019 diyAudio
