Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?
Old 23rd July 2019, 06:43 AM   #1431
GM is offline GM  United States
GM's Avatar
Yeah, 1.4" Altec/GPA is the only large format I've auditioned that can be used to 15 kHz @ > 104 dB, but at GPA's new pricing I'd rather use 2" and add a super tweeter.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 23rd July 2019, 07:37 AM   #1432
phase_accurate is offline phase_accurate
Hi Tuyen
Maybe you have given up too early with your combination. What is it about the sound that you don't like ? Keep in mind that definitely none of your drivers is a bad one. All of them are used in studio monitors, which is not a full guarantee but at least some indicator of quality.
How did you do the crossover ?
Charles
Old 23rd July 2019, 10:09 AM   #1433
tuyen is offline tuyen  Australia
Send a message via MSN to tuyen
Sorry in advance for my very completely subjective observations.
I was expecting a more 'open' or perhaps 'bigger' sound. Still 'clean' sound but no treble sparkle either. No doubting the build quality the Beyma drivers. I read on this thread previous that if driver MMS is > 100 then highest recommended cut would be ~500hz else clarity/resolution would suffer. Which makes sense as when I tried running the woofers around 600hz to 1000hz, the clarity/detail would suffer (even though datasheet of 15G40 states it has fr upto 1500hz and fr plot is flat-ish til there).
I tried various crossover frequencies (using Najda DSP). The bass xo point be around 200-300hz (12/18/24db cutoffs). The 12" coaxial would come in then and xo between the 12" woofer and the 2" hf cd around (1400-2000hz).
Old 23rd July 2019, 10:15 AM   #1434
200 to 300 Hz sounds reasonable. Did you do any measurements or did you just set the x-over by ear ? What is the box volume used for the coax ?
Charles
Old 23rd July 2019, 10:41 AM   #1435
AllenB is online now AllenB  Australia
It's difficult to make comments on this without ascertaining what you've done with each, whether they are the same and how etc..
..but, a lack of sparkle can be the result of a fixed, high DI?
Old 23rd July 2019, 12:08 PM   #1436
Agreed - the missing sparkle can be caused by narrow beamwidth. It can be re-gained with a supertweeter in this case.
The tweeter part of this coax has some humps in the lower part of its frequency response. Depending on how you set the tweeter level (by ear for instance) this might also result in a lack of highs. It is therefore advised to take proper care of these humps as well.
Charles
Old 23rd July 2019, 02:17 PM   #1437
badman is offline badman  United States
badman's Avatar
Originally Posted by Ro808 View Post
If the OB concept were the end to all loudspeaker concepts, it would dominate the market, I suppose.
Nearfield OBs have drawbacks that make them less than viable for general use. They would need to be given sufficient space, which doesn't align to general nearfield monitoring apps. They'd also be very poor at generating SPL for background music, or for multiple listeners.
So bad for a lot of reasons, but for an audiophile listening nearfield willing to jump through all those hoops they'll be not without their upsides too.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 23rd July 2019, 02:34 PM   #1438
Ro808 is offline Ro808  Netherlands
What's special about the HF1440? It's frequency plot doesn't look that balanced compared to something like the HF10AK ?
The plot looks exceptionally balanced for a large format driver.
HF10AK is a very good 1.75" dia driver, as is the HF108(R).
It's the usual trade-off, between top-end and midrange.
You might also consider the smaller 1.4" exit drivers (HF14.. series), like the one that Charles uses, for a 'best of both worlds solution'.
People often seem to ignore developments in diaphragm/suspension material, phase plugs etc.
Some large format drivers sound better than 1" exit drivers, even in the top octave.
Old 23rd July 2019, 02:50 PM   #1439
If I were him I would open a new thread dealing with improving the one he has.
While it is definitley addictive to always try new concepts it would also be interesting to get the best sound out of the cool combo that he already has. I would also modify the box for bass-reflex which is even easier with a three-way topoligy because there would not be midrange contamination from the reflex holes like large two-ways can suffer from.
Charles
Old 23rd July 2019, 03:27 PM   #1440
In that french thread there's an interesting notion on OBs. It's being considered as a short circuit.
The guy apparently chose OB for his basement, because it provides the best solution for some severe in-room anomalies.
Charles, completely agree with your statement on tuyen's Beyma drivers.
It would be a waste of these quality drivers to just move on to something new.
BTW, this post wears the 'magic number'
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?Hide this!Advertise here!
cascode distortion Spectrum. mashaffer Tubes / Valves 34 22nd January 2017 10:37 PM
6av5ga distortion spectrum enzoastro Tubes / Valves 14 30th January 2013 07:01 PM
Distortion spectrum vs feedback artosalo Tubes / Valves 62 8th December 2011 12:51 AM
What do you look for in the distortion spectrum? keantoken Solid State 13 13th May 2009 01:06 AM
Tailoring distortion spectrum syl Solid State 14 25th March 2002 08:32 PM
Copyright ©1999-2019 diyAudio
