Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?
Old 11th July 2019, 09:43 PM   #1241
Ro808 is online now Ro808  Netherlands
The latest Bullfrog is coming up.
Its driver is easy to recognize, but there is more to it.
The driver on the left image above is most likely a McCauley.
The Bullfrog was taken out of production for a number of years after the US manufacturer closed its doors.
Old 12th July 2019, 12:33 AM   #1242
camplo is offline camplo
Did someone mention the woofer? That would be the jewel of the design. That and the horn, but being crossed at 650hz, wtf? The majority of the woofer is covered by the horn, that would have to be the major drawback of the design though I'm not sure how that fairs out. I guess since its symmetrical from every angle, eq takes care of that problem. Also, the horn is too small to load properly to 650hz but I guess its more of a waveguide so whats the totality of that? Lowered sound quality I suppose. I'm not knocking the design, I love it actually, but I am trying to nit pick....makes me feel better since I am already invested into my/our design. At the very least, my bottom line was 30ish to 20khz-ish, linear, fewest amount of drivers possible. I think at the beginning of the thread I was talking of FAST (aka WAW?) configurations. The bullfrog isn't going to play linear into the 30's but it would make a nice combo with subwoofer, for sure. Just for fun, is there a nice woofer and horn available for the DIYer to create their own Bullfrog? I didn't even know you could buy horns that fit into the available coaxial woofers.
Old 12th July 2019, 01:16 AM   #1243
....on axis that is, the polar has to suffer from this alignment, I'd think.
Old 12th July 2019, 01:23 AM   #1244
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
For example, the previously mentioned Product Detail - RCF
Old 12th July 2019, 01:29 AM   #1245
I like it! I was interested in the Beyma co-axials briefly...like has been said, there is no silver bullet....yet.... I would like to find some affordable wooden horns though. Otherwise I am happy with the path that I am on. I've come to understand that fiberglass horns have their own set of drawbacks and why wood is the sought after horn.
Old 12th July 2019, 01:33 AM   #1246
There are plenty of 15" coaxials with horns available from B&C, Beyma, BMS, Oberton, RCF etc.
The RCF CX15N351 is quite special, because of the bigger compression driver.
The horn is rather small indeed. In order to enlarge the mouth somewhat, Martion mounts the inner convex Aluminium ring.
Old 12th July 2019, 01:41 AM   #1247
But! The RCF in the Bullfrog is made to Martions specs. And while there's no complete list, because these are trade secrets, I can tell the mods are subtantial.
I'll post more info later. l'm on the phone now.
Old 12th July 2019, 01:58 AM   #1248
The RCF is a nice coax, but I would prefer a soft suspension in the comp.
The driver is basically the N640.
According to the info I've gathered Martion uses another diaphragm, but the big break-up spike is still visible in measurements of the latest Bullfrog.
Old 12th July 2019, 02:28 AM   #1249
The good thing about the RCF CX15N351 is presumably a better handover between woofer and comp.
The passive Bullfrog, which was reintroduced some time after the active, has a 1" comp. and XO at 1500Hz.
The driver is, again, not identical to the RCF 15CXN251.
Old 12th July 2019, 02:51 AM   #1250
GM is offline GM  United States
GM's Avatar
They both have the same problem in that its Fs needs to be either well above or well below its pass band and why the pioneers opted for thin tin horns encased in tar.
For the DIYer; MDF, better still, cheap particleboard with concrete, stone, etc., obviously best, then properly seal the inside since there's no such thing as too smooth, especially in the first 4-5" [includes any driver internal throat], just a point of diminishing returns.
Anybody tried any of the new super slick spray coatings used on race cars, etc., on horns?
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?Hide this!Advertise here!
cascode distortion Spectrum. mashaffer Tubes / Valves 34 22nd January 2017 09:37 PM
6av5ga distortion spectrum enzoastro Tubes / Valves 14 30th January 2013 06:01 PM
Distortion spectrum vs feedback artosalo Tubes / Valves 62 7th December 2011 11:51 PM
What do you look for in the distortion spectrum? keantoken Solid State 13 13th May 2009 12:06 AM
Tailoring distortion spectrum syl Solid State 14 25th March 2002 07:32 PM
Copyright ©1999-2019 diyAudio
