Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?
Old 21st June 2019, 05:45 AM   #1131
GM is offline GM  United States
GM's Avatar
Ventilated cab for high Qt driver, so usually will have some form of damping or just a 'sock' cover for ~OB.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 21st June 2019, 06:37 AM   #1132
phase_accurate is offline phase_accurate
Ask the builder ! He is also a member of this forum !!! Have you seen the end-product as well ? There is felt over the slots in order to get resistive loading.
Regarding speakers too large fo a certainn room: There is some truth to it because you will need to sit farther away when using lots of large drivers because of better driver integration. Thats where the need for larger room dimensions come from. Driver integration wouldn't work well in the nearfield with a large four-way speaker for instance. There is of course a chance to get it right with setting the correct delays and driver corrections on a DSP. But that large four-way that has been tuned to be listened to in one exact nearfield spot wouldn't work that well anymore at a larger distance in turn.
If a Speaker is optimised for a larger listening distance then there is a greater range of listening distances where it works fine.
Charles
Old 21st June 2019, 01:39 PM   #1133
mark100 is offline mark100  United States
Originally Posted by GM View Post
OK, but why does this decide parallel Vs series wired? I mean in parallel you're using way more current, which heats up the VCs quicker, holds it longer = higher average and peak temps = higher effective Qts with the potential upside of lower inductance [Le] whereas the increased [Le] in series can be either a bonus or not depending on how much it has and the intended app.
Anyway, I'm old school, so my query was a many decades old rote response without remembering that 16 ohm rated amps are MIA in mainstream audio, so never mind. :P
GM
Hi GM, I still get that voice coil heating is the same either in series or parallel.
Take 800W applied to 2 ohms parallel. P=I^2*R 800W=20A^2*2R. V=40
Each driver sees 40V, and 1/2 the total current or 10A
Take 800W applied to 8 ohms in series. P=V^2/R 800W=80V^2/8R A= 10
Each driver sees 1/2 the total voltage or 40V, and 10A
So, if math is correct ?, there is the same voltage and current to each individual driver either way.
Only difference is demands on amp...current vs voltage.
I strongly suspect the wiring choice is primarily being made based on amp wattage output specs.
The amp being used is stronger current wise, than voltage wise.
Old 21st June 2019, 02:13 PM   #1134
Ro808 is offline Ro808  Netherlands
Originally Posted by camplo View Post
What we got going on here ������
It's a (variable) resistance enclosure.
More info here.
Old 21st June 2019, 02:35 PM   #1135
Yes, but once you drop to a constant 2 Ohm load....
For PA or HT it's another story (if the number of available amps is limited), but the (professional) amp designers I know, as well as loudspeaker builders all prefer a minimum load of 4 Ohms, or (better): 8 Ohms or higher (for tubes).
It may come across as 'audiophool rubbish' to some, but from my experience low power amps tend to sound better.
That's my conclusion after comparing several high end pro amps (MC2 and the like) to mid and higher end consumer amps (tubes, class A, A/B, D etc.).
Why not make optimal use of the higher efficiency that larger drivers entail?
Old 21st June 2019, 03:01 PM   #1136
For PA or HT it's another story (if the number of available amps is limited), but the (professional) amp designers I know, as well as loudspeaker builders all prefer a minimum load of 4 Ohms or better: 8 Ohms or higher (for tubes).
Yeah, I'm not a fan of 2 Ohm loads either, even for PA use. There are a few prosound amps such as Linea Research and Powersoft that I'd be happy running at 2R.
The QSC PLX's don't fall in that category. IME, they need a real stiff line supply to keep from dropping out at 2R.
QSC's PL3's and PLD's are OK, but PA inevitably uses longer speaker wires, and damping factor realistically becomes an issue.
The last nail in the coffin for 2R imo, is it is usually used for gaining wattage.
But like diyuser2010 pointed out, thermal compression kicks in waay earlier than most folks realize, so what's the point?
I've heard folks say the point is for headroom.....but headroom comes from maintaining necessary rail voltage, and as per earlier thread, voltage and current to individual drivers remains the same...
Wattage is really a confusing, muddy spec, ....
Old 21st June 2019, 03:05 PM   #1137
QSC's PL3's and PLD's are OK, but PA inevitably uses longer speaker wires, and damping factor realistically becomes an issue.(
Agreed, that's why I stated: "those amps tend to be quite expensive".
You could build a high quality large format 2 way stereo loudspeaker system and have enough money left to buy amps, dsp and a nice (used) workstation for the price of one Linea Research amp.
Old 21st June 2019, 05:35 PM   #1138
Originally Posted by phase_accurate View Post
Regarding speakers too large fo a certain room: There is some truth to it because you will need to sit farther away when using lots of large drivers because of better driver integration. Thats where the need for larger room dimensions come from. Driver integration wouldn't work well in the nearfield with a large four-way speaker for instance. There is of course a chance to get it right with setting the correct delays and driver corrections on a DSP. But that large four-way that has been tuned to be listened to in one exact nearfield spot wouldn't work that well anymore at a larger distance in turn.
Charles
This is true. I've found 2-ways are the easiest to work with, in a large variety of rooms. This applies to both small (BBC type) monitors and larger cabs + horn / wg.
Again, a Synergy / MEH would be better still.
Old 21st June 2019, 06:10 PM   #1139
I am sure even these could work wonderfully. Yes, those are 2241H 18s (thanks to GM for the reference to the FB page, earlier).
Old 21st June 2019, 09:31 PM   #1140
norman bates is offline norman bates  United States
norman bates's Avatar
low powered amp............
A theory is all the dc (with noise) that is sitting on the output devices that are unused messes up sound quality.
Then again, my 200w@8ohm sounded gorgeous, but it so old as soon as it is fixed, it acts up again in a month or 2.
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?Hide this!Advertise here!
cascode distortion Spectrum. mashaffer Tubes / Valves 34 22nd January 2017 09:37 PM
6av5ga distortion spectrum enzoastro Tubes / Valves 14 30th January 2013 06:01 PM
Distortion spectrum vs feedback artosalo Tubes / Valves 62 7th December 2011 11:51 PM
What do you look for in the distortion spectrum? keantoken Solid State 13 13th May 2009 12:06 AM
Tailoring distortion spectrum syl Solid State 14 25th March 2002 07:32 PM
Copyright ©1999-2019 diyAudio
