Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?
Old 21st June 2019, 12:17 AM   #1121
Ro808 is offline Ro808  Netherlands
Found this reprint of an old interview with George Augspurger on Control Room Acoustics and Studio Monitor design (Recording Engineer/Producer (RE/P) Magazine, March / April 1974 issue).
Old 21st June 2019, 12:23 AM   #1122
GM is offline GM  United States
GM's Avatar
Originally Posted by camplo View Post
What say you?
Sure! Changing times......... the pioneers began with just 8 W IIRC, so systems had to be max efficient and accept its size, etc., shortcomings. Neither did they initially concern themselves too much with a BW wider than the analog telephone's 250-2500 Hz decade.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 21st June 2019, 12:33 AM   #1123
I think the main factor in listening distance is the number of drivers and directivity
There are so many factors involved with a loudspeaker in an arbitrary room, that it's very hard to be conclusive in this respect.
Ideally, you want a loudspeaker system that more or less 'gets the room out of the way'. A Synergy or MEH comes to mind.
Old 21st June 2019, 01:01 AM   #1124
camplo, I came across a post by natehansen66, he's also a member of this forum.
These are directivity plots of his dual AE TD15M in 3 cu ft sealed cabs, angled in to create about a 120° angle between the baffles. Ground plane measurement at about 12' (I believe this was done in order to mimic Augspurger monitors):
This is his thread on his DIY fiberglass 18" EOS waveguides.
Old 21st June 2019, 01:53 AM   #1125
camplo is offline camplo
I was just reading in that article, you shared, they angle the woofers in order to create wider dispersion in the mid range where beaming might otherwise exist.
Old 21st June 2019, 02:11 AM   #1126
Brett is offline Brett
Brett's Avatar
OK heres another argument I got myself into, I didn't necessarily support the idea of a driver being "too big" for a given room size.
What do you guys think.
It's rubbish.
Old 21st June 2019, 02:43 AM   #1127
I was pretty sure but figured I ask the people who really knew
Old 21st June 2019, 03:35 AM   #1128
In the Augsperger interview the JBL 2220 is referred to.
IMHO & FWIW, the "B" series is one of the best looking 15s ever.
Old 21st June 2019, 04:42 AM   #1129
GM's Avatar
Originally Posted by diyuser2010 View Post
Seating is approximately ~ 18 feet to the front wall, so roughly ~16 feet to the speakers, almost 5 meters. To produce 105 dB at the seating from each channel takes a decent amount of power.
OK, but why does this decide parallel Vs series wired? I mean in parallel you're using way more current, which heats up the VCs quicker, holds it longer = higher average and peak temps = higher effective Qts with the potential upside of lower inductance [Le] whereas the increased [Le] in series can be either a bonus or not depending on how much it has and the intended app.
Anyway, I'm old school, so my query was a many decades old rote response without remembering that 16 ohm rated amps are MIA in mainstream audio, so never mind. :P
GM
Old 21st June 2019, 04:43 AM   #1130
What we got going on here 🤔🤔🤔
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?Hide this!Advertise here!
cascode distortion Spectrum. mashaffer Tubes / Valves 34 22nd January 2017 09:37 PM
6av5ga distortion spectrum enzoastro Tubes / Valves 14 30th January 2013 06:01 PM
Distortion spectrum vs feedback artosalo Tubes / Valves 62 7th December 2011 11:51 PM
What do you look for in the distortion spectrum? keantoken Solid State 13 13th May 2009 12:06 AM
Tailoring distortion spectrum syl Solid State 14 25th March 2002 07:32 PM
Copyright ©1999-2019 diyAudio
