Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?
Old Yesterday, 03:33 PM   #1031
Ro808 is offline Ro808  Netherlands
Originally Posted by Bas Horneman View Post
Bummer. Ordered and paid. Got refunded. Prices are up. Looks like it was a mistake on their website.
Too bad.
Prices presumably applied to drivers in stock.
I believe the French guy bought a pair at the low price.
Old Yesterday, 03:49 PM   #1032
daemonsgr is offline daemonsgr  United Kingdom
Originally Posted by Ro808 View Post
I was referring to a pair for two 2-ways
2 x 8 ohm in parallel would be perfect for a MEH (> future project).
The woofer you said is 16ohm I think. Maybe I misread! (That is way I said 16 and 16 in parallel) ill check.
Old Yesterday, 05:57 PM   #1033
I accidentally referred to the 16 ohm version, not intentionally.
Old Yesterday, 06:27 PM   #1034
docali is offline docali  Germany
docali's Avatar
What is missing for me is the Siemens Eurodyn which is a classic 2-way speaker system to cover the whole spectrum.
Old Yesterday, 06:40 PM   #1035
Agreed, but the standard Eurodyn doesn't do much below 50Hz.
Old Yesterday, 07:09 PM   #1036
Following the route of Faital vs the world...
DE250 vs a good Faital? (1in)
Old Yesterday, 07:32 PM   #1037
This or this.
16 Ohm version of the HF109 looks very good too.
Old Yesterday, 08:06 PM   #1038
Impression of prototype 2-way with Fatial Pro HF108R - 16 ohms mounted to LTH102 & Faital Pro 12PR320 - 8 ohms.
1 kHz is a critical XO point for a 1" driver. The Beyma CP380M takes it easily, even crossed slightly lower.
Other 1" drivers, like the BMS I have, don't sound so good around 1 Khz.
For 900Hz and below, I would always use a larger diaphram (>1.75").
Much depends on the horn though > in general, a bigger horn facilitates a lower xo point.
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?Hide this!Advertise here!
cascode distortion Spectrum. mashaffer Tubes / Valves 34 22nd January 2017 09:37 PM
6av5ga distortion spectrum enzoastro Tubes / Valves 14 30th January 2013 06:01 PM
Distortion spectrum vs feedback artosalo Tubes / Valves 62 7th December 2011 11:51 PM
What do you look for in the distortion spectrum? keantoken Solid State 13 13th May 2009 12:06 AM
Tailoring distortion spectrum syl Solid State 14 25th March 2002 07:32 PM
Copyright ©1999-2019 diyAudio
