Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?
Old 16th June 2019, 03:39 PM   #1001
Ro808 is online now Ro808  Netherlands
It does.
The cone is different though, especially around the dustcap.
Moreover, despite its generous X-max, the Beyma wouldn't appreciate port tuning at 22kHz.
They pretend to use TAD, but that presumably applies to the comp. driver.
The only TAD woofer with a similar cone/dustcap is the TL-1602, but that one has a foam surround instead of a triple roll.
Old 16th June 2019, 06:46 PM   #1002
Originally Posted by daemonsgr View Post
Are Faital CD better in terms of quality (for hifi I mean) than beyma for example? Something crossed around 1khz.
It depends on your application.
Beyma is on par with Faital quality wise.
Beyma also offers a few low priced large format cone drivers that are still very good, whereas Faital's portfolio is smaller and more aimed towards the mid and higher end of the market.
I like Beyma 1" compression drivers very much, but would prefer Faital for 3" diaphragm drivers.
The Faital 3" drivers are very hard to beat.
I'll check out the HF1440 shortly.
Old 16th June 2019, 08:18 PM   #1003
The CP-380/M, CP-385Nd have been benchmark 1" drivers for years.
They sound good, measure well, play lower than nearly any other modern 1" driver, without nasty sonic artefacts.
The newer drivers (CD-10Fe/N, CD-10Nd, CD-11Fe, CD-11Nd etc.) are also very good.
For hifi the difference is probably neglectable.
The CD-11Nd with PM4 polymer diaphragm is interesting:
The 44mm Faital drivers would work crossed around 1kHz, especially the HF108 and HF10AK.
Old 16th June 2019, 08:56 PM   #1004
daemonsgr, I assume you are located in the UK?
This is probably the best driver currently available in Europe at €65 each, if you order a pair.
The only possible downside is the radial phase plug, that usually works better with Tractrix and similar horns.
Old 16th June 2019, 09:17 PM   #1005
This is the diaphragm of the HF10RK:
It'll sound in accordance with its looks: velvety smooth, or like someone commented: painfully smooth.
Old 16th June 2019, 10:26 PM   #1006
daemonsgr is offline daemonsgr  United Kingdom
wow! better than more expensive faital models?
does the same (bayma vs faital) follows the woofers? I was aiming for a 15p80nd (got some bad comments for the 2226h I had as a first choice) but do faital get better quality sound and response?
thanks
Old 16th June 2019, 11:53 PM   #1007
camplo is offline camplo
Limmerhorns
Old 17th June 2019, 12:16 AM   #1008
How can MTM be a favorable config when the woofers are spaced farther apart vs say a TMM. When ctc is of two drivers producing the same freq. range, and the wavelength becomes shorter than the distance of the ctc, are there not negative side affects?
Old 17th June 2019, 12:34 AM   #1009
No, it's not better than the more expensive Faitals, but it's good especially at the current sale price > it's discontinued.
You won't find a similar Nd driver for that kind of money.
After my previous post I came across a recent DIY project on a French forum.
The thread starter did exactly what I would strongly discourage: mount the HF10RK to a diffraction horn (JBL 2370 clone).
Evidently, it didn't work out.
Old 17th June 2019, 12:49 AM   #1010
Originally Posted by camplo View Post
This is a very good Limmer horn and used in numerous diy projects and kits in Germany, one of which is called "Tricolore":
If you search "Limmer 033", you'll find many measurements with different drivers.
It was also used in this (German) high end loudspeaker:
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?Hide this!Advertise here!
cascode distortion Spectrum. mashaffer Tubes / Valves 34 22nd January 2017 10:37 PM
6av5ga distortion spectrum enzoastro Tubes / Valves 14 30th January 2013 07:01 PM
Distortion spectrum vs feedback artosalo Tubes / Valves 62 8th December 2011 12:51 AM
What do you look for in the distortion spectrum? keantoken Solid State 13 13th May 2009 01:06 AM
Tailoring distortion spectrum syl Solid State 14 25th March 2002 08:32 PM
Copyright ©1999-2019 diyAudio
