Small La Scala Tutorial for noob
Old 15th March 2019, 08:58 AM   #71
David McBean is offline David McBean  Australia
Originally Posted by sumotan View Post
so many programs including Hornsrep canít be downloaded to windows 10 software.
Hornresp works with Windows 10.
www.hornresp.net
Old 15th March 2019, 09:29 AM   #72
sumotan is offline sumotan  Indonesia
Sorry I never said that Hornspresp cant work with W10, Im block from downloading Hornsresp & some other programs as well. Can’t explain why but it’s happening on my laptop.
Cheers
Old 15th March 2019, 05:02 PM   #73
freddi is offline freddi  United States
freddi's Avatar
@sumotan - Unfortunately, SIZE can matter with loudspeaker cabinets and especially when downsizing from something functional. When going down in size, LF cutoff is pushed upwards as are effects in the response and one can end up with a cute looking cabinet with no real merit and perhaps with more effort than something larger and usable.
Look at the "stubby horn vent" ~28 liter system below vs a simple liter reflex and then a 28 liter simple vent reflex. The system the 28 liter stubby vent example was derived from was a design by "RCA-Fan" (Bill Woods is a big fan of RCA's Harry F. Olson). At full size that vent puts a little bit of "hit" into the response - nothing like JBL's Harkness which had a small chamber and sizable back horn).
The little stubby horn vent system (one name for them back in the 1950's/60s) moves that rise in response from the "hit" region up to where its really not good (imo).
The huge Vitavox Thunderbolt looks pretty good at 0.7 scale as starts out big and has a usable 1/4 wave path after scaling.
So you might pick up on a pretty big cabinet to scale downwards - or make a new design.
I showed some of the previous sims of real small cabinets in the corner - to smooth them somewhat and try to get down to around 100Hz.
Old 15th March 2019, 05:32 PM   #74
Hi Freddi, thanks again for your advice. What you say really makes sense.
Was googling for the Vitavox Thunderbolt plans but unfortunately no exact
details.
Thank you again for all your time & advice
Old 15th March 2019, 06:22 PM   #75
freddi's Avatar
I was told by a horn expert that that one side view sketch of a Vitavox Thunderbolt is proper and to dimension it vs the woofer's frame diameter in the drawing.
Here's the woofer's PDF showing a 15" dimension
http://www.vitavoxhifi.co.uk/pdf/151_engineering_2.pdf
Old 15th March 2019, 07:12 PM   #76
GM is offline GM  United States
GM's Avatar
Sorry I never said that Hornspresp cant work with W10, Im block from downloading Hornsresp & some other programs as well. Canít explain why but itís happening on my laptop.
Cheers
Oops! Another late, late over night 'senior moment'.
Hmm, I've had this every time [install and update] since I 'downgraded' from 2k Pro to 7 pro 64, telling me it looks like something from a 'nasty' site, but allows me to override it and DL anyway.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 15th March 2019, 07:22 PM   #77
freddi's Avatar
I've had "Paint" crash a few times today - very annoying to have to give permission to open a picture file- what's good about Win10 seems to be mitigated with their stupid "updates"
Old 15th March 2019, 07:33 PM   #78
GM's Avatar
Do you have it setup to only DL/install security updates?
GM
Old 15th March 2019, 08:01 PM   #79
freddi's Avatar
I've not setup Win10 yet on my new/old PC
Old 16th March 2019, 12:58 AM   #80
freddi's Avatar
btw sumotan - if you cut William Cowan's 2-19 sub in half down the middle for one driver, the response looks reasonably good ( at little peaky on the bottom) - it would like more back chamber volume - so you could increase the cabinet height to get more back volume without increasing build complexity. GM - do you think William's assumption of the corner effect to still apply out to 1M? that would smooth things - I think.
Small La Scala Tutorial for noobHide this!Advertise here!
Diode Tutorial & How to build an AC to DC power supply - NOOB FRIENDLY VIDEOS dakku Power Supplies 3 5th June 2014 10:01 AM
very small noob question project 88 godslayer Analog Line Level 15 25th May 2013 03:51 PM
la scala clone or else? PreSapian Multi-Way 30 16th November 2012 10:36 AM
A7, La Scala or what??? superfunk Multi-Way 14 2nd January 2011 11:51 AM
[noob] Looking to build a really, really small sub Lindell Subwoofers 18 13th November 2007 03:16 PM
Copyright ©1999-2019 diyAudio
