Small La Scala Tutorial for noob
Old 15th March 2019, 01:03 AM   #61
sumotan is offline sumotan  Indonesia
Wow very nice .
Hi Fredi
May I ask whatís causing the dip at 400hz ? Is it the design of the bin regardless of woofer used ? As suggested by GM, would adding the corner 45deg wedge at the corner when the horn turns 90 deg towards the exit help flatten the respond somewhat ?
Thank you
Old 15th March 2019, 04:16 AM   #62
freddi is offline freddi  United States
freddi's Avatar
I don't think little reflectors would help. Those graphs are power response and the on-axis response will be rising vs the drop in power. I think the flat part of La Scala's path where there's no expansion is the cause of some shelving.
not all is known how something will respond til its built and measured.
with a tiny horn as such, I would push it back into a corner.
I used the "Edgar" sim from the Klipsch forums and not sure if the flat portion would be that long -?
Here's the model - I'll have to squint and look at it again
https://community.klipsch.com/upload...9455497062.png
Old 15th March 2019, 04:39 AM   #63
Thank you for the enlightement Freddi.
The Bec2Biex looks good. You think it will measure well if we scale down to use with the 10Fw64 ?
Cheers
Old 15th March 2019, 06:54 AM   #64
freddi's Avatar
It might (?) - can you work out its expansion? What kind of amplifier do you intend to use? - its output impedance could matter.
Old 15th March 2019, 07:00 AM   #65
I’ve got an Aksa 100 amp, a 30 watt 6Bq5 nfb tube amp & going to build a Pse 300B amp.
I know nuts about horn speakers hence seeking for advice & tuition. This will be my first diy speaker project. Will be a good tutorial for myself.
Old 15th March 2019, 07:29 AM   #66
freddi's Avatar
GM is better at this stuff than myself - but FWIW - here's 10FW64 in a 0.66 scale University Classic, sitting in a corner - it won't be real little nor go deep but probably would be pretty darn loud and clear
I reduced the back chamber in these sims down to a ridiculously low 5 liters so it would handle 40v in its passband without exceeding xmax - that's 135dB without taking in effects of compression.
in a corner, its 50% efficient
File Type: jpeg A449E60D-5480-40D3-9B1A-EFBA06AB2491.jpeg (309.8 KB, 30 views)
Old 15th March 2019, 07:42 AM   #67
Thank you again Fredi. I think Microsoft is getting pretty nasty, so many programs including Hornsrep can’t be downloaded to windows 10 software.
Old 15th March 2019, 08:07 AM   #68
freddi's Avatar
I run hornresp on Win10 with old Optiplex
here's a 2/3 scaled reflex with big vent in the corner - only a cubic foot airspace
maybe you can ask GM to to a MLTL for 10FW64
Old 15th March 2019, 08:09 AM   #69
GM is offline GM  United States
GM's Avatar
Hmm, can't comment about upgrades from this past year, but HR worked fine on W10 before that. I actually loaded it on a Dell W10 in the store before willing to buy it.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 15th March 2019, 08:15 AM   #70
Well your a cleverman GM. The terrible thing about W10 even when I set update to be notified it will still update by itself & Iíve noticed the more it updates the more protection that I see W10 putting in. Sigh
Thanks GM
Whats the width of the reflex box & thickness of panels used ?
Thank you kindly again Freddi.
Btw Freddi, why do you call it reflex when the loading looks like a short back loaded horn. Oops sorry, does Id depth represents the internal width of the box ?
Thank you
Small La Scala Tutorial for noobHide this!Advertise here!
Diode Tutorial & How to build an AC to DC power supply - NOOB FRIENDLY VIDEOS dakku Power Supplies 3 5th June 2014 10:01 AM
very small noob question project 88 godslayer Analog Line Level 15 25th May 2013 03:51 PM
la scala clone or else? PreSapian Multi-Way 30 16th November 2012 10:36 AM
A7, La Scala or what??? superfunk Multi-Way 14 2nd January 2011 11:51 AM
[noob] Looking to build a really, really small sub Lindell Subwoofers 18 13th November 2007 03:16 PM
Copyright ©1999-2019 diyAudio
