Dayton diy
Dayton diy
Old 15th March 2019, 07:09 PM   #21
jkthn is offline jkthn
Now i am very pleased with the crossover setup,but without measured the speaker.
But simulated crossover in xsim is not same as reality,i notised that right now.
Is someone having a setup like this?
Dayton rs1504p and Seas h1396 setup,and having some of there own crossover suggestions of this diy project...
File Type: jpeg 8B96AFE2-C0F0-4F8F-8996-024FEA726DAB.jpeg (379.5 KB, 101 views)
Old 17th March 2019, 06:08 PM   #22
David Morison is offline David Morison  Scotland
Averaging 2Ω impedance across so much of the spectrum will tax a lot of amplifiers - make sure you're using one that's happy with such a low value, or redesign for a higher average impedance.
Actually, just noticed what's causing that - L2 should be after (ie on the driver side of) C2, not before it.
Also, I think you've got more shaping than I'd want to see at this stage - the slope down from LF through the mids might be OK if it is to compensate for bafflestep, but I think the rise from 2kHz to 15kHz is probably too much - it might sound nice at first, but would be better long term if flatter.
Old 19th March 2019, 07:26 PM   #23
Yes,the impedance vent very bad,want is your thought about this mew idea?
Old Yesterday, 09:20 AM   #24
Looks better to me.
It's worth turning on the phase trace for each drivers curve in the response graph to check they're pretty close too. Of course, if the two FRD files have not had their measurements taken in exactly the same way (eg mic distance from baffle) then any phase/timing info extracted from them will be at best approximate, but it's probably still worth doing.
Dayton diyHide this!Advertise here!
For sale pair of Dayton Rs225 woofers and Dayton rs28f Tweeters viki_v2 Swap Meet 0 30th August 2013 06:24 PM
Peerless XXLS vs. Dayton Reference vs. Dayton Titanic MKIII ? wigginjs Multi-Way 6 3rd March 2008 08:56 PM
Dayton DA aluminum cone woofer + Dayton DC28f tweeter springy101 Multi-Way 7 15th March 2006 05:22 PM
Dayton 6" reference and dayton silk dome tweeter combo project...input? nerd of nerds Multi-Way 4 2nd December 2004 05:36 PM
Dayton 5.25" AL vs. Dayton 5.25 paper for Lo-Mid opinions? netgeek Multi-Way 6 14th May 2004 01:14 PM
Copyright ©1999-2019 diyAudio
