Quick question for the experts
Old 3rd March 2019, 07:30 PM   #21
denibeni is offline denibeni
Ok, if the Wilmslow crossover is 2nd order electrical (i think it is) on the low- and high-pass, then i say it's is a very rough one.
The 0.9mH low-pass coil combined with the 20uF cap is simply does not provide any baffle-step compensation and the tweeter high-pass combined with the L-pad does not attenuate enough in this situation.
Not surprisingly, it didn't work well.
Old 3rd March 2019, 09:02 PM   #22
giosblue is offline giosblue
There are two coils, one is 0.9mh and the other is 0.6mh?
To say it didn't work well is an understatement. It is terrible.
I don't have the knowledge and expertise to sort this out, I just want to buy the bits and fit them.. The AE crossover is a 2nd order 12db octave and it crosses over @ 2.5 khz, whatever that means.
One good thing, I should be able to get these drive units working in these cabinets. If the AE crossover works as well as it does, then a tailor made one should be even better?
Old 3rd March 2019, 10:51 PM   #23
Galu is offline Galu  Scotland
If you asked the supplier to design crossovers specifically for your Scanspeak drivers then they should replace them if not working as intended.
Please update us after contacting the suppliers and hearing what they have to say.
Old 4th March 2019, 06:10 PM   #24
Ok, update as promised. I sent Wilmslow a picture of the x/overs they provided and asked them was this the correct one for the two drivers I was using. The reply was was.
Sorry about that, to be honest I'm not sure what has happened, as the design looks spot on this end.
Anyway they are obviously not doing the job they were intending to do, so please send them back and we will either sort them out or refund the cost.
Wilmslow have been in business a long and are very experienced in what they do, however there response does leave me a little uneasy. If the design of these x/overs are spot on, why do they sound so bad and why do the AE x/overs that were not designed for the Scanspeak drivers sound so much better? Anyway I'm having them collected and they are going to take a look at them. My concern is, suppose they can't find anything wrong?
They said they would refund me, but then I would have two expensive Scanspeak units working with a x/over that wasn't designed for them. And who in their right mind would spend over 600 on top quality drivers and then compromise their performance with an inferior x/over.
The plot thickens.
Ron
Old 4th March 2019, 06:59 PM   #25
Default One I found n the internet.
This is a crossover the same drive units I have, how does this look?
File Type: png ellam-flex-6600_XO-layout-wiring-small.png (84.3 KB, 149 views)
Old 4th March 2019, 10:48 PM   #26
You should be looking at the R3004/662000 version where the 10uF cap is changed to 8.2 uF and the attenuation resistors have different values. Scroll down this link to find the correct component values:
Ellam-FLEX
(Note that this crossover has been designed to suit your drivers, but specifically when mounted in the Ellam FLEX enclosure, so may not produce the same result in your boxes.)
Again, I would wait to see what your crossover supplier comes up with.
Old 13th March 2019, 02:30 PM   #27
Mine is the D3004/66000 tweeter. Anyway, the boys at Wilmslow have had a look and they agree that it is not right and they are going to sort it out for me.
I'll let you know when it's sorted.
Old 13th March 2019, 06:13 PM   #28
My mistake - I got confused about the tweeter
I wouldn't expect Wilmslow to come up with a replacement crossover quite as complex as the one you illustrated, but hopefully it will work to your satisfaction.
Looking forward to you reporting a positive outcome!
Old 13th March 2019, 06:19 PM   #29
The plan is to send me one crossover and see how that works, if it's ok they do another one.
Old 7th April 2019, 05:29 PM   #30
Ok folks, sorry about the delay to the update. The x/o Wilmslow did was a mile of. They checked it and thought it was spot on. Anyway, I sent them back and it turns out the Scanspeak have changed the spec on the15w8530koo and they agreed it was wrong. They sent me new x/o which were much better but still not right, not hadsgood as the AE x/o.so, for the moment I'm using them. I have also changed the cabinets, I bought some Wharfedale Diamond 11.1s and I have fitted the Scanspeak drives into them.They are really nice boxes and with a couple of mods everything is a perfect fit.. However, having done all this, I can't help thinking they would sound even better with a x/o specifically designed the the Scanspeak drivers and the new box. This is not something I can do. I have seen a crossover on the internet for this combo but it looks a bit complicated and bulky. Given that Scanspeak drive units are very popular with the diy guys, there must be some who can help me?
ron
Quick question for the expertsHide this!Advertise here!
Question for Lateral Fet experts schillg11 Parts 2 5th March 2019 07:25 AM
A question for the pc audio experts jez PC Based 4 23rd December 2011 07:03 PM
Question for Kindle experts jez Everything Else 14 23rd December 2011 01:06 AM
A question for the experts Vaughan Subwoofers 36 20th August 2007 09:40 PM
A Question To The Experts Here mastertech Solid State 16 6th March 2006 11:52 AM
Copyright ©1999-2019 diyAudio
