A dip at around 10KHz. Reason and correction.
Old 21st February 2019, 09:14 PM   #1
Aucosticraft is offline Aucosticraft  India
Default A dip at around 10KHz. Reason and correction.
I got CX120 -8 CX120-8 4" Coaxial Driver with 3/4" Silk Dome Tweeter 8 Ohm Specification Sheet for project.
In the tweeter Frequency response published, No where I see a graph having "T" drop at around 10Khz . But in my measurements it shows this drop, when I measure at a distance around 15mm from tweeter dome. I thought its my measurement equipment problem. So I checked it with the other dome tweeter I had in spare. But measurements were all Ok. I took another frequency response measurement placing mic only 3 mm away from the tweeter dome of CX120-8. and the "T" drop did not appear. Unable to understand I tried to measure frequency response of the woofer part of CX120 -8. and there too i got to see such "T" drop , although the frequency of "T" was shifted.
So
1) The Question is this a geometry of the driver creating the problem? Or its something else.
2) How to correct it?
3) And why is this "T" Drop not seen in the Manufacturer's measurement.
Note: The graph attached is of CX120-8 coaxial driver. tweeter and woofer part.
Orange Colored FR graph is of tweeter measurements at a distance of 3 mm.
Green Colored FR graph is of tweeter measurements at a distance of 15 mm.
Blue Colored FR graph is of woofer measurements at a distance of 15 mm.
There is always a first time....
Old 21st February 2019, 09:29 PM   #2
David Morison is offline David Morison  Scotland
10kHz has a wavelength of about 34mm - your measurement distance is fairly close to half that, making me think it may be some kind of cancellation?
If so, measuring a bit further out may get rid of it - or at least shift it lower in frequency, confirming it as a measurement artifact and not a driver anomaly.
Old 22nd February 2019, 02:26 AM   #3
Thanks, Its giving me the dip even when I carry measurements from a feet. I will update the snapshot in a day or so. I am currently away from my home location.
Old 22nd February 2019, 06:49 AM   #4
Sonce is offline Sonce  Macedonia
You should measure at 1 m distance.
Almost all coax tweeters exhibit strong dip on axis in the range 8 - 10 kHz, except KEF and Tannoy coax tweeters. That dip disappears off axis at 30 degrees or so.
Old 22nd February 2019, 07:55 AM   #5
Sure, I will try that. And update here in a day or two, once I am back to my home location.
Old 22nd February 2019, 11:27 AM   #6
Quip is offline Quip
Out-of-phase radial reflection at the tweeter-midwoofer cone transition interferes with the tweeter's output at 10kHz. Geddes briefly talks about it here.
Old 22nd February 2019, 12:44 PM   #7
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Yep, it is almost unavoidable, like throat resonance in compression drivers. KEF's tangerine "phase plug" seems to help, but we diyers are helpless with other drivers.
Because of being an interference cancellation, it can be equalized only partially, and it has minimal effect in farfield and power response
Radikal aktivist AINOgradient speaker project
Old 22nd February 2019, 07:32 PM   #8
plasnu is offline plasnu  United States
Even if you can correct this dip somehow, I don't think you will hear any difference. Just pretend that you didn't see it.
Old 22nd February 2019, 07:39 PM   #9
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
Maybe measure off-axis a bit (maybe 20degrees)?
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 22nd February 2019, 07:56 PM   #10
silverprout is offline silverprout  France
silverprout's Avatar
It will be worse.
Things I Should Have Learned In School (But Probably Didn't)
A dip at around 10KHz. Reason and correction.Hide this!Advertise here!
Do some tweeters intentionally have a peak at around 10KHz? andy2 Multi-Way 5 1st July 2017 02:55 PM
Quartz Tuner Reads 10khz Out? redrooster Digital Source 15 22nd August 2015 02:35 PM
Which measurement microphone for 20~10KHZ? wyan Equipment & Tools 3 4th December 2014 01:04 AM
Damping factor of 100 at 10KHz? rhythmsandy Solid State 38 5th October 2014 08:17 PM
Class D BandWith DC to 10KHz mederic Class D 3 25th November 2010 07:35 AM
Copyright ©1999-2019 diyAudio
