A dip at around 10KHz. Reason and correction.
Old 22nd February 2019, 08:02 PM   #11
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
^most often it gets smoother - at 30¤ plus. And this applies to deep waveguides too!
SEAS MR18 with aluminium tweeter and SEAS T18
Radikal aktivist AINOgradient speaker project
Old 22nd February 2019, 08:28 PM   #12
silverprout is offline silverprout  France
silverprout's Avatar
Sorry i've take a deep for a peak, i remember a terrible issue with a ribbon tweeter, on your measurements the cancelation is tamed by still there.
IMHO, people are minimizing the problem in order to reconfort Aucosticraft.
Things I Should Have Learned In School (But Probably Didn't)
Old 24th February 2019, 12:45 PM   #13
Aucosticraft is offline Aucosticraft  India
I am back to my home location, Here is the frequency response measured from a distance of 1 meter @ 0 Axis. The dip looks shifted and looks useable.
There is always a first time....
Old 1st March 2019, 02:42 PM   #14
While thinking on , your all suggestions and theory, A thing stuck to me is , why don't we see those dip in the manufacturer's FR measurement. ie what they do to avoid the dip in there measurement.
Reference: CX120-8 4" Coaxial Driver with 3/4" Silk Dome Tweeter 8 Ohm Specification Sheet
Old 1st March 2019, 04:07 PM   #15
Because the manufacturer measurements are performed in a anechoic room, and your measurements are performed in a reverberant environement, the reverberant field is smoothing the dips in the far field.
Old 1st March 2019, 04:28 PM   #16
Juhazi's Avatar
That specific driver's cone diameter is only 85mm and it has a textile dome 3/4". Looks like it has off-axis dip at 15deg instead! At those frequencies very small details matter.
Old 2nd March 2019, 10:21 AM   #17
At the beginning of the formation of the sound wave every small error can become a big mistake
Here you can see a good design :
Here you can see a bad design :
Do you see the difference ?
Last edited by silverprout; 2nd March 2019 at 10:29 AM. Reason: Do you see the difference ?
Old 4th March 2019, 01:05 AM   #18
Somehow I feel this driver selection was a wrong choice. I have never used coaxial driver before. And I bought 8 of those thinking they would do good job for Home theater 7.1.
Old 4th March 2019, 03:36 PM   #19
You can glue a hollowed wizzler on the exterior periphery of the tweeter suspension, at first you can try some prototypes made with some sheets of paper and a pair of scissors.
A dip at around 10KHz. Reason and correction.Hide this!Advertise here!
Do some tweeters intentionally have a peak at around 10KHz? andy2 Multi-Way 5 1st July 2017 02:55 PM
Quartz Tuner Reads 10khz Out? redrooster Digital Source 15 22nd August 2015 02:35 PM
Which measurement microphone for 20~10KHZ? wyan Equipment & Tools 3 4th December 2014 01:04 AM
Damping factor of 100 at 10KHz? rhythmsandy Solid State 38 5th October 2014 08:17 PM
Class D BandWith DC to 10KHz mederic Class D 3 25th November 2010 07:35 AM
Copyright ©1999-2019 diyAudio
