Need help - w/ QSC HPR152i Clone based 2-way
Old 20th February 2019, 12:30 AM   #1
Dkalsi is offline Dkalsi  United States
Default Need help - w/ QSC HPR152i Clone based 2-way
So I'm new to speaker design and am hoping fellow forum members can assist with a simple 2-way build.
I have built several speaker kits to date, but have never designed anything on my own and thought I try my hand at something (hopefully) simple:
I have the following parts on hand:
Waveguide B-52 PHRN-1014: B-52 PHRN-1014 1" Horn 10" x 14" Bolt-On
Based on posts on other threads, many indicate this might be a clone of the NLA QSC HPR152i
For Compression Driver, I have the following Tymphany DFM-2535R00-08
Now, I have the following questions:
1) When taking measurements of the WG + driver, is there is a need to include a series capacitor to protect the CD? I'm not measuring at loud volumes on anything. I should have asked this question before, but I ended up taking a few measurements already.
2) If the answer to the above question is "Yes" - would it not impact the measured phase? I'm currently measure using ARTA's semi-dual method. If I use a 50uf or 80uf - it seems to impact the response (albeit slightly). How does one typically account for the impact of the protection capacitor on the measured response and phase, when one gets to the crossover design stage.
I've attached a couple of measurements, one showing the impact of including a protection capacitor, and the other showing the off-axis response to 60 degrees. - Please disregard the SPL Magnitude - I didn't take these measurements at 110db.
Lastly, I'm looking for (mid-) woofer recommendation. Don't want to spend too much since it's my first go. So far, I have $25 for the waveguides and $80 for the CDs. I'm budgeting $200 for the woofers.
Depending on the feedback I get in regards to the recommended safe crossover point for the CDw/WG, if its over 1200hz, it is my understanding that I should go with a woofer no larger than 12" (to make sure the center to center distance between the CD and the woofer is less than the wavelength at the crossover point).
Thoughts?
Old 22nd February 2019, 01:35 PM   #2
Thoughts anyone?
Old 22nd February 2019, 08:02 PM   #3
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
I'd personally aim initially for about 1.1k or 1kHz as crossover, but exactly where will depend on the measurements you make of the drivers in the cabinet. You can make measurements of a CD without a protection cap but, of course keep the level reasonable. I even do it at the 2.83Vrms standard level, which is quite loud. Ask my wife!
A good woofer I'd look at might be the Eminence 2512 Deltalite, would help keep the sensitivity up. Will take some shaping in the crossover, but if you have good measurements and a good crossover design program (Xsim or PCD or VituixCAD for example), that's not really hard to do. I would make at least 3 separate models (and sets of measurements), though, one at 0deg on-axis, one at about 20deg (horizontal) off-axis and one at about 40deg off-axis so you can optimize for off-axis response as well as the on-axis. If you plan to run your speakers with toe-in (advised), then focus particularly on the 20deg model choosing crossover points that work best also at 0deg and 40deg.
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 22nd February 2019, 08:31 PM   #4
Thanks for the recommendation Bwaslo.
Yes - the measurements were definitely taken at low volumes. I plan on taking measurements out to at least 60deg (like the measurements included above) once I have the enclosure built.
I'll look into the Eminence. They are slightly on the pricey side for me (at $155/each), but maybe their performance will justify the cost.
I was curious how something like the Dayton PA310-8 would fare - they are currently on sale for $60 each.
Old 22nd February 2019, 09:56 PM   #5
bwaslo's Avatar
You could do worse than the PA310-8, really. I just like neo drivers, that's all.
Old 23rd February 2019, 04:26 AM   #6
LineSource is offline LineSource  United States
LineSource's Avatar
This is my understanding.....
-tymphany-DFM-2535R00-08 has small 1.4" diameter dome
A 10" midwoofer like the $140 Deltalite_II 2510 with a crossove frequency around 1.5-1.6kHz selected to match the polar response of the B-52 PHRN-1014 waveguide would be a good complement to your DFM-2535R00-08.
The $57 Faital 10FE200 with Fs=55Hz and Qts=0.6 = BIG box with modest bass
This CD has also been used at lower crossover frequencies with 12" midbass for modest demand home speakers. Polar measurements for 1250Hz crossover look very good. I would experiment with BW3 and LR4 circuits to best protect this 1.4" diameter CD.
-tymphany-DFM-2544R00-08 has 1.75" diameter dome
A 12" midwoofer like the Eminence $155 DeltaLite 2512_II or superior $205 Kappalite 3012HO with a crossover frequency around 1.2-1.3kHz selected to match the polar response of the B-52 PHRN-1014 waveguide would be a good complement to a DFM-2544R00-08 .
-tymphany-DFM-2535R00-08 has 1.4" diameter dome
Peerless by Tymphany DFM-2535R00-08 Compression Driver | audioXpress
Test Bench: Peerless by Tymphany DFM-2544R00-08 Compression Driver | audioXpress
Old 23rd February 2019, 01:22 PM   #7
Thanks LineSource -
I did also consider the DMF-2544R00-08. I know it can dig a little lower and has twice the power handling. However, I wasn't sure if the B-52 PHRN-1014 waveguide would provide much boost below 1.2Khz. So even though the 2544 could play lower, I wasn't sure that, when combined with the WG, will I have a nice smooth (workable) response, or will I have a little bump in the response because the driver can continue playing below the cut-off frequency of the WG.
I'm certainly within the return window for the DFM-2535, if you think the DFM-2544 would be a better route for a 2-way. It's only marginally more expensive.
I'll also model out the Deltalite 2510 vs DeltaLite 2512.
This build is mainly for our living room for some background music. While I do play some tracks loud from time to time - I'm not chasing after the same SPL that some of my AVSForum member DIY enthusiast chase :-)
Old 24th February 2019, 01:35 AM   #8
LineSource's Avatar
Since you want good 2-way bass,
and since the B52 waveguide is 14" wide,
and since you can exchange your 1.4" DFM-2535R00-08 for the 1.75" DMF-2544R00-08,
it seems logical to get the DMF-2544R00-08 and purchase a 12" midwoofer like the Eminence DeltaLite 2512-II to help justify the exchange with the store.
Eminence DeltaLite 2512-II will produce -F3 =43Hz in about 4.5-5cuft ported cabinet. 18" wide cabinets have a "good look" in most rooms, tall and reasonable depth yields 4-5cuft. You can find a few example EconoWave crossovers for the DeltaLite 2512-II at 1200-1300Hz.
Eminence DeltaLite 2512-II woofer -F3~44Hz
Old 24th February 2019, 09:38 PM   #9
EarlK is offline EarlK  Canada
DK,
I'd think very carefully whether or not to trade this raw response
for this one .
That second curve will require a bit more tonal shaping ( iow; 2 to 3 PEQ notchs ) to hammer into a flattish response ( though it's eminently do-able ).
The ( proto ) introductory thread ( created over at TechTalk called Impressive New Compression Driver where we put the Tymphany DFM2535 through it's paces also produced a pretty consistent opinion that the driver would be easy to EQ & HiPass due to it's quite linear response and low Fs .
Here are some examples :Click the image to open in full size. and Click the image to open in full size. and Click the image to open in full size.and Click the image to open in full size.
You'll recognize the 4th pic in the series as an XSim prediction .
The point of all my XSim predictions was to show how easy it is to get good looking HF curves using the Tymphany 2535 on the PRV ( 152i clone ) .
That XSim prediction was produced by this simple HP network;
A major concern I have is that your Tymphany DFM2535 ( on the B52 version of the 152i Clone ) is nowhere near as linear as I have come to believe this driver/horn combo should deliver.
I'm wondering if there's a difference in your drivers ( compared to our 2016 vintage models ) and/or whether your B52 horn is injecting a lot more ripple into the drivers raw response.
I believe Bill Waslo still uses & promotes these drivers, so maybe he can offer an opinion if their 2019 response is the same as back in 2016.
Old 24th February 2019, 09:50 PM   #10
Earl,
Thanks for the link and measurement curves.
I measured with the pairs of divers on the pair of horns and they measured near identical (only slight difference above 18Khz).
I don't know why I'm getting that bump centered around 2Khz (or maybe 2Khz fine and I'm getting a dip around 3K-4K?).
Don't know what's going on?
Need help - w/ QSC HPR152i Clone based 2-wayHide this!Advertise here!
Generic Asian Clone driver board RE and Clone jacampb2 Car Audio 26 3rd July 2018 08:01 PM
DIY st70 based kit but not clone dabenza Tubes / Valves 21 12th August 2017 06:05 PM
QSC HPR152i waveguides Jonhny Multi-Way 52 5th January 2017 05:24 PM
FS: Drivers for JBL 250Ti clone (LE14, 108H clone, 104H-2 GordonW Swap Meet 10 20th May 2014 08:19 PM
WTB: QSC PL-000446GP Waveguide Horn for HPR152i Kovax Swap Meet 0 3rd June 2012 06:09 PM
Copyright ©1999-2019 diyAudio
