Simple high efficiency two-way
Old 19th February 2019, 05:51 PM   #11
freddi is offline freddi  United States
freddi's Avatar
one could make a Druid (or whatever) style cabinet with Eminence's current B102 plus a Morel Cat 37-8 dome with only a 5.6uF cap as the crossover. It would be moderate in efficiency. Box/pipe volume would probably best be somewhat larger than the Druid and around 1.7 - 2 cubic feet
Diuid sized pipe with only lining and old spec Eminence B102 - it would be somewhat smoother with light fill
comparison of the orignal low Qts B102 to the present model:
Old 19th February 2019, 06:02 PM   #12
chris661 is offline chris661  United Kingdom
chris661's Avatar
First-order filters are difficult. The drivers need a wide range where they can overlap and maintain power handling, avoid peaks in the frequency response, etc.
You can get something reasonable with a Faital Pro 10HX230 and a single component for each driver, although power handling is limited and the phase curves don't line up fantastically.
I found better results by going to 2nd order filters - more power handling, and better frequency response.
Sensitivity came in at about 97dB@1w.
Chris
My work: www.grimshawaudio.com
Old 19th February 2019, 06:10 PM   #13
moray james is offline moray james  Canada
why not buy a Dynaco A25 or A35?
moray james
Old 19th February 2019, 06:31 PM   #14
freddi's Avatar
If you listen at what I consider moderate levels, with 5.6uF a Morel CAT378's dome can be seen moving
42 liter pipe w. B102 - a bit bigger wouldn't hurt - don't forget to think about the amp output impedance
a classic Dynaco A25/A40XL in good shape would be nice
Old 19th February 2019, 06:41 PM   #15
adason is offline adason  United States
adason's Avatar
Defo, ever considered good coaxial? Tannoy, or something cheaper, B&C...plenty coaxials to choose from. Pro speakers typically have higher efficiency.
Old 19th February 2019, 07:47 PM   #16
Ugg10 is offline Ugg10  United Kingdom
If you have deep pockets the Beyma pro coaxials, as identified by @adason, may do the job.
LOUDSPEAKER 12CXA400Fe 8 OH
This is a 12 which you can buy a pre built crossover (12db slope, 2nd order) for. Data sheet shows combined response with the crossover
Old 19th February 2019, 08:36 PM   #17
ScottG is offline ScottG  United States
Originally Posted by Defo View Post
Maybe a Dayton PM220 wideband woofer with a Dayton AMTPRO-4 or something?
Any suggestions?
-baffle-step loss is going to kill your eff. with that combo.
Yeah, a suggestion:
18Sound | ND1480A
XT1464
The Raptor ... a 10" MTM
and at about 20" wide with a volume around 3 cubic feet (sealed):
15W500
Target filter should be similar to the Spica TC 60 (though an octave lower):
Spica TC-60 loudspeaker Measurements | Stereophile.com
-probably a box-on-stand aesthetic similar to TonyG's (though not vented), and with a bit of backward "tilt" to aim the midbass to the listener, perhaps more like the Avantgarde Zero (but without the tweeter):
perspective is everything
Old 19th February 2019, 08:47 PM   #18
freddi's Avatar
that's a cool 18Sound woofer - a 450uF series cap (assuming low impedance drive) should make it go flat- lower. I'm not sure of the impact that might have on sound quality.
Old 20th February 2019, 08:50 AM   #19
Defo is offline Defo  Norway
Very interesting to see the differences between the old one and the new here!
You mean buy and forget, or pulling some drivers from it?
Very nice curve with the cap on that Morel! How does it compare to the Seas DXT I wonder?
Chris
I've been looking at the DIY Sound Group Volt 10 coax. Seems pretty nice for the money, and I get a free lunch with a finished crossover.
Those Faital coaxials look quite nice tho. Even if the curves are quite smoothed and low resolution. Couldn't find any unofficial measurements of them.
Are there any finished projects / crossovers for one of these coaxes anywhere I wonder? Preferably one that includes BSC.
Originally Posted by ScottG View Post
Too large a system for me unfortunately
I was actually thinking of building a TV-bench with integrated speakers on each side. Something like this:
Old 20th February 2019, 10:19 AM   #20
frankmalz is offline frankmalz  Germany
Have you seen the pispeakers?
http://www.pispeakers.com/Prices.html
One,two and two towers have very simple filters
Simple high efficiency two-wayHide this!Advertise here!
FS: Pair of Radian 5208C-8 high-end coax high-efficiency drivers GordonW Swap Meet 6 9th February 2015 02:15 PM
Power supply:Universal AC input/ Full range,High Efficiency, and High reliability hang Vendor's Bazaar 12 24th July 2009 03:46 AM
Low wattage, high efficiency, high quality? Nordic Multi-Way 5 4th September 2005 11:12 PM
High Efficiency, High Power Handling? Bogie Multi-Way 3 2nd July 2005 05:49 AM
switching power supply :simple,high efficiency .Please help thanh Power Supplies 14 2nd December 2004 03:11 AM
Copyright ©1999-2019 diyAudio
