Multi-amp thought experiment
Old 12th June 2019, 10:22 AM   #31
kipman725 is online now kipman725  United Kingdom
kipman725's Avatar
Send a message via MSN to kipman725
Originally Posted by Moondog55 View Post
There has been no interest in my old Rotel 8 channel amp but it is too good to give away. What can I do with a small cheap DSP and 8 * 40 watts? At my first thought that isn't much for bass but that 40 * 4 is equal to most 150watt power amps I've ever owned and those never seemed shy of bass power. 3-Way or 4-Way? I haven't opened up the box for the DSP yet as too much going on at the moment but I need to get my mind organised.
Whatever is going to happen will be in the context of the drivers I have in the shed and on the shelves but that selection is pretty broad and most of the better, smaller drivers will cope with 40 watts. Let's brainstorm even if nothing gets built for a while, I am a terrible ditherer and prevaricator and I think I prefer to tinker than do straight builds but I have the need to build something big soon
You probably need less power than you think, at home I struggle to get the first signal light lit on an inuke6000 running my subs, which is less than 40W per channel. That's with 12*15" sealed spread across the two channels equalised flat to 10Hz and then then a house curve which is +6dB @ 20Hz sloping down to -6dB @ 20kHz. So if you connected 4 subs to your amp I think you would have enough power.
Old 13th June 2019, 02:47 AM   #32
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
Unfortunately the woofers I have to experiment with are small and not particularly efficient and really only suitable for sealed boxes. Although there is an alternate in a big OB that I might get around to building one day
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Multi-amp thought experimentHide this!Advertise here!
Computer speakers Thought experiment help Moondog55 Multi-Way 26 22nd February 2013 06:31 AM
The Chinese Room Thought Experiment thadman The Lounge 43 19th December 2012 11:53 PM
Just a thought experimentů no1herenow Multi-Way 29 23rd January 2012 06:35 PM
Who Wants To Be A Millionaire? (a thought experiment) thadman The Lounge 10 11th May 2011 09:54 PM
BIB thought experiment Brisso57 Full Range 3 27th January 2009 03:13 PM
Copyright ©1999-2019 diyAudio
