Multi-amp thought experiment
Old 12th February 2019, 09:44 PM   #21
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
Originally Posted by 00940 View Post
Knowing what you have, especially wrt woofers, would really help to narrow down options. I really like the satellites plus small subs idea but if you don't have the drivers for it...
Knowing the intended use and the size/shape of the room would also be a big plus.
That's the thing I already have the speakers for stereo use and I don't "need" anything, so the build would be simply for fun and experimentation and as a learning exercise in the use of DSP.
One of the thoughts I had is to replicate something Lynn Olsen posted on at the start of the Beyond the Ariel thread. Multiple woofers with first order roll-offs at each octave step, something that was impractically impossible at a cost effective level for me .
So first step at 80Hz, next at 160Hz and a final roll-off a steeper level at the XO to the midrange/tweeter Just to see if it sounds as Lynn said it should, excellent low bass
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 12th February 2019, 11:18 PM   #22
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Thanks for that Bon. The use is a small sub < 60Hz.
If there are no dogs in Heaven, then when I die I want to go where they went - Will Rogers
Old 13th February 2019, 06:52 PM   #23
Bon is offline Bon  Australia
I highly recommend using two in force cancelling mode. Use 10" (250mm) or 12" (300mm) drainage pipe with woofers in end. A rigid pipe is incapable of "pumping" due to internal pressure. The end baffles can be made thick and glued into the tube. The tensioning rods the hold them firmly in place. I had a saucer of water balanced on the tube with high level sub 20 Hz tones. Not a ripple when the walls, doors and windows were flexing madly. The volume is your choice but I found 60 cm pipe length (400mm diameter) was perfect for 2x12". An internal mdf central disc brace was glued in but I don't really think it was necessary. The best sealed sub I have ever built by a long way.
Old 13th February 2019, 10:37 PM   #24
rabbitz's Avatar
Reminds me of the sonotube subs that were being built a decade ago.
Old 11th June 2019, 05:58 AM   #25
Moondog55's Avatar
Where did all the time go?
Since my last post the garage fell down and all the drivers went into short term storage -[ Hah ! Famous last words] and I have been laid low with a dose of walking pneumonia that will not go away. However I am still thinking about doing something with that amplifier eventualy. When we get the new shed built and after the ski season
Old 11th June 2019, 08:17 AM   #26
Ugg10 is offline Ugg10  United Kingdom
Keeping an eye on this thread.
I have managed to get two RMB1066's so a choice of 6,5,4 or 3 channels per amp at 60W or 150w depending on whether you bridge channels or not. Also looking out for a Minidsp NanoDigi DSP which will then play through either 4 Khadas ES9038Q2M boards or I have been looking at the Lucid 88192 8 channel ADC/DAC that can be had for about the same price second hand (older Delta Sigma DAC).
Still tossing a coin over whether to carry on with my own TMWW design using 2xES180TiA + 10F8424 + SB26CDC in a 40l floor standing BR (looking at Xmax on this system looks like it max's out at around 50w on the bass drivers so no real benefit of running it bridged) or build a NAO Note RS II (using all 6 channels for each driver).
Interested in the idea of 1st order and a driver per octave, sound like a great experiment.
Old 11th June 2019, 12:22 PM   #27
Moondog55's Avatar
Second thoughts on that
IF
Big if there. I was to make a WWW MTM and doing a passive OX on the mid Tweeter and using Lynn Olsens idea should all 3 woofers be the same?
I think I may actually still have 6 cheap 10" woofers in the stash
Old 11th June 2019, 12:33 PM   #28
AllenB is offline AllenB  Australia
There may be a benefit in the multiple woofers spreading amongst the room modes.
Originally Posted by Moondog55 View Post
OX
This is an out of phase XO
Old 12th June 2019, 07:59 AM   #29
Brett is offline Brett
Brett's Avatar
That sucks. I got a dose about 12 years ago and the doctors I went to misdiagnosed it for months and I lost so much weight I looked emaciated. Then I ran into a Doctor I'd studied with who proposed a course of treatment that saw me well in a couple of weeks. Still took months to recover fully.
I hope you get over this soon.
My first thought was (the late, great) John Entwistle playing, just not an Alembic or a Stealth.
/bass nerd mode.
Old 12th June 2019, 08:06 AM   #30
Moondog55's Avatar
The replies [ retorts?] are too good to go back and edit/fix the typo
Multi-amp thought experimentHide this!Advertise here!
Computer speakers Thought experiment help Moondog55 Multi-Way 26 22nd February 2013 06:31 AM
The Chinese Room Thought Experiment thadman The Lounge 43 19th December 2012 11:53 PM
Just a thought experimentů no1herenow Multi-Way 29 23rd January 2012 06:35 PM
Who Wants To Be A Millionaire? (a thought experiment) thadman The Lounge 10 11th May 2011 09:54 PM
BIB thought experiment Brisso57 Full Range 3 27th January 2009 03:13 PM
Copyright ©1999-2019 diyAudio
