Does the driver pattern change the dispersion pattern?
Old 10th February 2019, 04:47 PM   #11
mark100 is offline mark100  United States
Originally Posted by system7 View Post
To reverse time you need IIR.
Are you referring to zero phase?
Where IIR is applied bidirectionally?
Old 11th February 2019, 11:11 PM   #12
Ok, part 2
PLS nevermind previous questions...
I see zero phase, bidirectional IIR, requires a signal storage buffer to 'look backwards in time',
so in my mind it has the same latency issue as linear phase FIR does,
but with much greater computational complication.
It's kinda easy to see why zero phase hasn't made a splash...
So there's no real time reversal......it takes time to fix time, eh?
Does the driver pattern change the dispersion pattern?Hide this!Advertise here!
What quality makes a Narrow Dispersion Pattern for Midrange Driver Megalomaniac Multi-Way 18 28th June 2017 12:32 PM
Dispersion pattern of clustered drivers perceval Full Range 24 20th April 2017 02:18 PM
EnABL Pattern for this driver? (Bud?) enigmaticEntity. Multi-Way 2 29th September 2010 05:39 AM
Driver pattern, directivity and other confusing issues mefistofelez Multi-Way 2 19th January 2006 04:56 AM
Copyright ©1999-2019 diyAudio
