Measuring driver parameters vs the data sheet values
Old 11th February 2019, 08:42 AM   #21
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Oh I think I need more sleep, now I see it. You switched drivers
Can you post the actual impedance plots from the T/S measurement run?
Tony.
Any intelligence I may appear to have is purely artificial!
Photography (another hobby)
Old 11th February 2019, 08:47 AM   #22
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
Originally Posted by ggidzinski View Post
...initial box sizing was way off because the data sheet specs are BS.
George
Now you understand that speaker units are not nuts & bolts, their specs change with climate conditions, age, different materials introduced in production line, etc. You are wasting your time searching for a better way of measuring TSP. I have got Audiomatica Clio, one of the best performing measurement systems in their own time, the 90's of the past century, and I also measure this kind of changes, with Scan Speak, Visaton, Peerless...only Focal and Dynaudio were spot on.
Old 11th February 2019, 03:17 PM   #23
ggidzinski is offline ggidzinski  United States
ggidzinski's Avatar
Originally Posted by ente View Post
...before going on with your discussion about measurement software /systems have a look at this Klippel paper:
https://www.klippel.de/fileadmin/kli...equency_fs.pdf
Heinrich
Thank you, this is interesting. Unfortunately it only prolongs the dilemma of figuring out how to determine a box volume for two drivers sitting on my work bench with measured TS parameters that are off by as much as 50% from the data sheet. I still donít know if my measurements are of any value or if I should even be considering doing my own measurements given that I canít spen $5k for this process. Since this thread has enlightened me that measurement condition, order, calculations, etc all affect the result I will restate my earlier question:
Some of you have recommended solutions for raw driver TS parameter measurement like CLIO and Smith & Larson WT2. Do any of these also provide detailed instructions on how to measure to get proper results (proper order, how to do added mass for Vas, warm up driver, etc)? I find for instance that my added mass process is not repeatable so I have little confidence in the results.
Thanks,
George
Musician since 1961, fell in love with audiophile equipment in 1969 when I first met the mesmerizing blue glow of a vintage McIntosh and JBL L300ís. DIY fever started in 1978 watching a pair of Klipsch hornís being built in a garage.
Old 11th February 2019, 03:42 PM   #24
celef is offline celef
If i remember correctly there is described in the clio standard manual a procedure how to get correct drive level for measurements of driver parameters
Old 11th February 2019, 04:24 PM   #25
ggidzinski's Avatar
Tony.
Sorry about the confusion. I started pulling drivers to see if I have a consistent problem and I did wind up doing the burn in experiment with a different one.
This is an Aura NS3-193-8A that I bought new that sat around for a few months but was not used. I played music material through it for 24 hours this week to burn it in. Here are the data sheet specs (A), the initial TS measurements with DATS2 (B), and TS measurements after 24 hours of burn in (C). Also attached is the impedance plot of today's 24 hr burn in measurement as well as the data sheet. I did not include Vas because I can't get consistent measurements on this parameter using added weight:
Aura NS3-193-8A:
--------A------B-------C
Re---7.60---7.72---7.77
Fs------80---123----116
Qts---0.67--0.87---0.88
Qes---0.73--1.08---1.06
Qms--8.00---4.49--5.08
Thanks,
George
File Type: pdf 296-258_AuraSound_NS3-193-8A_Specifications (1).pdf (901.3 KB, 3 views)
Old 11th February 2019, 04:34 PM   #26
ente is offline ente  Germany
http://parkaudio.ua/DOCz/knowledgebase/aes02-2012-f.pdf
Chapter 5.4
Heinrich
Old 11th February 2019, 04:35 PM   #27
ggidzinski's Avatar
Originally Posted by planet10 View Post
T/S are curves, not scalars.
Different measuring kit pulls the number from a different part of the curve, so measures can be significantly different. Also whether the sw estimates the parameters or actually measures them. Short of the pro stuff the factories use (ie $5k-ish), Smith+Larson Woofer Tester 2 is probably the best short of them.
I always start with the factory numbers,i have rarely had to redo a box. Also keep in mind that depending on the manufacturer parameters will vary from plus-minus 5% to plus-minus 20& or more.
I use S+L for driver matching and unknown drivers.
dave
Smith & Larson WT2 looks interesting as they claim very good accuracy and repeatability. One thing that I have learned here is that measurement techniques and conditions matter a lot. Do they include good instructions on the process to be able to achieve their claimed results?
Thanks,
George
Old 11th February 2019, 04:44 PM   #28
ggidzinski's Avatar
Thanks. I suspect that in the case of this small driver that I may have problems with the light added mass weight vibrating under test. In you tube videos guys are measuring giant woofers with water bottles attached to rolls of tape. I have layers of post it notes on mine, measuring them with a sensitive gram scale. Do I need to attach my weight to the surround with double sided tape or something?
Thanks,
George
Old 11th February 2019, 05:44 PM   #29
you can use coins for weights
some uses magnets on either side of the cone
some uses clay
Old 11th February 2019, 05:45 PM   #30
ggidzinski's Avatar
do you let the coins sit loose on the cone or do you tape them down?
Thanks,
George
Measuring driver parameters vs the data sheet valuesHide this!Advertise here!
Anyone have a data sheet for these ??? Dagwood Parts 3 3rd February 2013 10:07 AM
U3090MG (Display Driver Vishay-TFK) for FV112 Futuba Data Sheet wanted tiefbassuebertr Solid State 8 31st January 2012 09:21 AM
How Do I Measuring Driver 'Acoustic Data' Loren42 Multi-Way 23 16th March 2010 05:37 PM
op amp/dac data sheet help Smiffy Parts 11 13th December 2004 09:14 PM
data sheet KCC Parts 5 6th January 2004 10:03 PM
Copyright ©1999-2019 diyAudio
