Mid-bass Horn Design help
Old 7th February 2019, 10:33 PM   #11
RobWells is online now RobWells  United Kingdom
RobWells's Avatar
Originally Posted by Rob Dingen View Post
I simulated a tractrix horn with B&C 12PE32.
That simulate really good also.
What do you think about this design?
I have a pair of 80Hz horns similar to the Edgar horns using Electrovoice EVM 15L drivers. I'm pretty sure they have a throat around 500cm2. If you are using a 12" driver then I think the throat can be smaller. When I prototyped these horns they ended up around 60cm long. I also built a prototype JBL 2020H 12" driver horn that worked out around 80cm long with a smaller throat suited to the smaller driver.
Old 8th February 2019, 01:11 AM   #12
hottattoo is offline hottattoo  United States
Check with Bert Doppenberg if you have not already. He has some nice horn designs and drivers.
BD-Design, only the best!
Old 8th February 2019, 02:18 AM   #13
freddi is offline freddi  United States
freddi's Avatar
take a good look at John Inlow's 12pe32 horn schematics ("Diy 100Hz Midbass Horn") - he gives enough info there to model.
inlowsound.com
here's an approximation of his 135Hz 12pe32 horn vs your input
Old 8th February 2019, 03:14 AM   #14
freddi's Avatar
I'm on a tiny monitor and didn't realize the inputs were at "CON" - plus could not get the length the same using "T"
@ RobWells - that's a fabulous graph with the EV15L horn
Old 8th February 2019, 03:16 AM   #15
chromenuts is offline chromenuts  United States
You would think this topic was thoroughly beaten to death.
Iíve been stuck in analysis paralysis for longer than Iím willing to admit over what mid bass horn I could pull off in my living room that would work with my Oris 200 and a variety of other midrange horns I either have or have drivers for.
The usual suspects have been mentioned...Volvotreter, Inlow Sound (BTW his 135Hz horn is based on the B&C 8PE21...not sure if you guys were just interested in the 12PE32 instead).
A few other links:
100 Hz Multi-sided Conical Midbass Horns - DIY Firefly
Guy started with Volvotreter and then kind of did his own thing.
Also the Quarter Pi...
Quarter Pie Bass Horn: Measured FR, How2Build, and Hornresp - Technical/Modifications - The Klipsch Audio Community
Iím sure thereís others Iíve forgotten about....thatís usually how it goes. There was several lengthy threads on here discussing various drivers like the Fane 8M in mid bass horns.
I have gotten as far as buying pairs of reconed Electro Voice EVM15B and the B&C 8PE21 drivers to experiment with.
I also tried modeling the 8pe21 in hornresp in a multi segment conical similar to Inlow. I didnít get quite the upper frequency extension that I wanted or that he shows on his site so I put it aside.
My recent re-read of an old interview with Edgar makes me want to try a hyperbolic mid bass. Inlow has some info on his site about a 60Hz crescent hyperbolic if I remember correctly.
Since I was spinning my wheels, I decided to give a dipole design a shot. Iím just finishing it up now.
BD Design was mentioned for his horn designs. Strangely enough, last I looked he came out with an iteration of a slot loaded dipole bass design utilizing 12 inch BMS drivers to use under his smaller full range horns. Previously he had an enormous stacked type of dipole with his 15 inch drivers and a horn lens on the front.
Old 8th February 2019, 08:17 AM   #16
Rob Dingen is offline Rob Dingen  Netherlands
Rob what was the Mic distance to mouth from those measurements?
Old 8th February 2019, 08:23 AM   #17
RobWells's Avatar
The JBL horn was outside measured groundplane at 1m.
The EVM I'm not sure possibly in room at seating.
These were built around 13 years ago and I'm having trouble finding the off axis measurements for the EVM horn. Will measure again once the weather gets better.
Rob.
Old 8th February 2019, 08:24 AM   #18
Originally Posted by Flaesh View Post
Ang 0,5 x pi seems too optimistic. Or will you really place horn mouth in corner?..
No gonna change that Thanks
Old 8th February 2019, 08:28 AM   #19
Originally Posted by chromenuts View Post
Gonna look at the links you give. I just pick a speaker with good parameters for a horn but I'm free to pick any. I also looked at the GPA515 as a good contender if you read the reviews.
Old 8th February 2019, 08:30 AM   #20
Thanks Freddi for the simulations going to experiment again.
Mid-bass Horn Design helpHide this!Advertise here!
DIY Yorkville U15 clone (Unity horn/multiple entry horn) gj00023 PA Systems 12 29th November 2018 05:16 AM
77Hz bass horn, Azura and GOTO horn project starts atilsley Multi-Way 6 9th November 2016 10:01 AM
Horn experts - Please help to determine optimal throat size for low-mid horn pk Multi-Way 9 19th August 2012 07:29 PM
Folded horn - volume between subwoofer cone ane th start of the horn benpalmer Subwoofers 8 9th April 2012 02:10 PM
12" full range on a backloaded horn, BIB, tappered quarter wave or other horn boxes? c3conv Full Range 1 27th July 2011 06:37 PM
Copyright ©1999-2019 diyAudio
