Crossover build
Crossover build
Old 24th January 2019, 06:53 PM   #1
ggidzinski is offline ggidzinski  United States
ggidzinski's Avatar
Default Crossover build
I am working on my first crossover network from scratch, probably a 2nd order 2-way. My questions are twofold:
1) Is there any difference in performance if I build them with point to point on a perf board vs using a stock foil board with the large pads/grounds?
2) Most of the stock foil boards are only for the basic 4 components plus maybe a fuse. What do you guys do for L pad resistors, Zobel, BSC etc? Is everything on the same board or is there a second board?
Thanks,
George
Old 24th January 2019, 07:36 PM   #2
wolf_teeth is offline wolf_teeth  United States
wolf_teeth's Avatar
Everything is on the same board for me, unless a single board will not fit. I use p-to-p wiring and try to use as few jumpers as possible, so layout is important.
Keep coils at orthogonal positions to each other if closely placed. Try to keep coils away from other metals in the box, as this will affect value, this includes driver magnets. Use Brass/Nylon mounting screws if screwing them down.
Try to keep breathing room around resistors in case they get hot, and use 10-15W minimum value.
I prefer pegboard and zip-ties, and maybe some glue if required. My glue of choice is E6000, and I use any old 80# tensile strength ties unless using small ones for resistors.
I've attached one of many examples.
Hope this helps,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 25th January 2019, 02:23 AM   #3
eriksquires is offline eriksquires  United States
eriksquires's Avatar
I've done some measurements and testing using DATS. Turns out those foil areas can couple with coils in unexpected ways.
Unless you absolutely had to, I'd do point to point all the way, or avoid using any foil conductors under a coil.
Best,
E
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Old 27th January 2019, 03:29 PM   #4
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
Before dissmising an idea entirely without a shred of evidence, particularly not understanding the impact of a potential change in inductor's inductance, which could be far less than the part value tolerance, I would advise not to worry about it.
Old 27th January 2019, 05:15 PM   #5
The issue wasn't that the inductance was changed, but that large lands under a coil can make a significant capacitor like coupling possible between the land under the coil and the coil.
Old 25th March 2020, 01:22 PM   #6
Jonny English is offline Jonny English  United Kingdom
Best,
E
Hi, can you advise the type of wire used to connect caps/ coils / resistors please. Is solid copper wire fine, is there a specific gauge that's best? Many thanks Jon
Old 25th March 2020, 04:36 PM   #7
waxx is offline waxx  Belgium
In, and many who don't use pcbs, solder parts to each other or use normal speaker wire (the ones you can buy cheap in bulk in most electronic stores).
Solid wire has no use for this, and is hard to connect to the parts, multistranded is way easier to work with and is as good.
Old 25th March 2020, 06:21 PM   #8
Douglas Blake is offline Douglas Blake  Canada
Douglas Blake's Avatar
Take a look at the leads on the parts ... any wire thicker than that is going to be just fine. Stranded is easier to work with, solid is easier to solder.
Old 26th March 2020, 07:30 AM   #9
Very helpful, many thanks!
Old 26th March 2020, 12:27 PM   #10
tuantran is offline tuantran  Canada
tuantran's Avatar
I like to use 16 AWG bare tinned copper to connect components (see picture). I connect 8 of 1uF capacitors to make 2 of 4uF capacitors.
Flat on-axis frequency response with wide bandwidth; wide, constant dispersion; low distortion and resonance.
Crossover buildHide this!Advertise here!
What can I buy or build as a crossover? Hextejas Analog Line Level 7 14th January 2019 04:12 PM
If i can build a Crossover, can I build an AMP? Prolle Solid State 1 6th January 2019 11:46 PM
Crossover build hifisucks Multi-Way 6 12th April 2013 06:42 AM
What should I use to build my own crossover? punkrokr1701 Parts 12 7th September 2006 03:18 AM
please help me build my crossover skylar112 Multi-Way 4 29th June 2006 11:40 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
