Old 25th March 2019, 06:51 PM   #41
GringoAudio is offline GringoAudio  Canada
Thank you Lojzek, I will try again tonight after work to put the FR and ZR files up.
Old 26th March 2019, 04:14 AM   #42
Yes the images with circuit diagrams on the left show the system response curves curves on the right.
So these attached files are the ZR and FR response curves as traced by me from ScanSpeak literature. As mentioned above I had to change the file extension name to .txt to be able to attach them to this forum. You will have to change them back to the extension names .FRD and .ZMA. I don't remember what I used to trace the curves. It's been awhile, a few years actually. I found it reading the X-Sim forum here though. It is mentioned somewhere there.
Old 26th March 2019, 09:46 AM   #43
verona is offline verona
Hi, I can't thank you guys enough!
I downloaded, renamed and read both files into x-Sim without any problems.
This has been a massive boost for me and I am really looking forward to doing some work on there.
I will look into tracing curves for my chosen tweeter and I will see if there is somewhere to post them on here when I have them finished.
Thanks again, Verona.
Audax pr170mo Woofer selection... which 15 inch woofer 98db eff... youknowyou Multi-Way 15 20th June 2017 05:37 AM
compromise = small woofer - larger (horn) midbass - what woofer types blend well? freddi Multi-Way 1 31st October 2015 12:15 PM
Woofer-Fullrange-Woofer vs Tweeter-Midrange-Woofer fakeout Multi-Way 5 11th August 2012 06:17 PM
WTB: 6.5" woofer to replace broken woofer in cheap band pass subwoofer Jimmy154 Swap Meet 2 5th October 2010 02:00 PM
Qts of Push-pull woofer and Compound Woofer System... haggy Multi-Way 1 13th December 2001 01:30 AM
Copyright ©1999-2019 diyAudio
