I am making a Pro 15 inch 2-way PA monitor with a eminence ASD:1001 compression driver paired with a Dayton Audio H812 1" Exponential Horn and a KAPPA PRO-15A as the woofer. The KAPPA PRO-15A has a Usable Frequency Range of 46 Hz - 4 kHz ,a Resonance(Fs) of 47 Hz and a vas of 5.92 cu.ft. I would like to know what would be the best tuning frequency for the enclosure.The speaker will be mostly be used for Hip-Hop,R&B and Dancehall applications
Box Dimensions
H27
W17.5
D18
An angle of 45° at length 8" for a monitor position
An angle of 45° at length of 3" for cosmetic purposes
Woofer link
Eminence Kappa-15LFA 15" Low Frequency Driver 8 Ohm
Box Dimensions
H27
W17.5
D18
Woofer link
I come up with 48.5hz.
what software did you use ??
If you mean a box meant as a stage-monitor for musicians ( & not PA Mains ) then I suggest a tighter ( more transient ) box tuning/alignment .
Typically that means something up in the 50hz to 60hz neighbourhood .
The stage will be blanketed by bass from the main rig & adding more LF only detracts from the stage-moniotrs duty ( which is to add voice clarity IME ).
This is why 12" woofers are still favoured for this duty ( they simply do a better job at melding with the LF back-wave produced by the Main PA ) while still providing enough bottom-end support for the singing voice.
thanks but i do mean a pa monitor similar to the Ev etx-15p and not necessarily a stage-monitor but i would like to be able to use it as such if the need should arise with the help of a drive rack and a passive crossover if even possible but the main issue now is finding the right tuning frequency for the enclosure that will complement the KAPPA PRO driver
- 2-way Pa monitor tuning
