inconsistent impulse response 2 different computers
1.....behringer uphoria um2 new laptop USB as input headphone 3.5mm as output
2.....phonic mu-802 mixer older laptop headphone output /mic input 3.5mm rca
bought brand new behringer u-phoria um2 external usb interface, but when measuring it was showing a rising high frequency response 15khz and above using jbl control 1 speakers, questioning the rising response, I switched to infinity modulus 1 and the top end dropped.
So using the um2 on new laptop
phonic mu-802 on old laptop
both connected to the same amplifier
both laptops have different versions of REW
here is a photograph of impulse response of both
phase response of both
new laptop to the left of pics.
if anyone asks for files to look at please tell me how and I will upload cheers
I would recommend NEVER using a headphone output for any measurements. This could easily be the source of the discrepancy/difference that you are observing.
To send the output from the computer to amp(s), use a proper DAC instead of a headphone jack. A $50 USB DAC will be way better than any headphone output.
yes, use line out connected to a power amp
before any testing of speakers, ensure your setup is good and consistant using hardwired loopback
frequency response should be very flat < +/- 0.1dB as should be the phase. (non smoothed)
with repeated tests, impulse should be at the same time and not move about.
