DIY 2-way design for a bookshelf
Old 12th February 2019, 12:44 AM   #41
zermak is offline zermak  Italy
Here I am again for some more support.
I've been playing with all the simulators I could find, using my measurements, and this seems the best option so far, just looking at the SPL response:
What do you think of the crossover?
I've run the ones suggested by LineSource but the SPL has a V shape which theoretically reduces the mid frequencies. Probably it's becasue of his -3dB for the baffle correction but my design is different than his.
And here it is: 420x240x300(+19+19mm). I also have the plans but on a PDF file. I can screenshot it if you need or want them.
I'll wait for your responses.
PS: I have also used Equalizer APO to test one speaker connecting one driver to L channel and one to R channel of my amplifier.
This above is what I measured using a 2nd order high pass filter with Q1 and -2,5dB on tweeter and a 2nd order low pass filter with Q0,3 for the woofer, both at 2100Hz.
DIY 2-way design for a bookshelfHide this!Advertise here!
looking for Morel bookshelf design msh1999 Multi-Way 11 8th March 2017 06:06 PM
Bookshelf Design for FE126 pcgab Full Range 11 1st November 2015 11:46 PM
need a crossover design for bookshelf arunpanchami Multi-Way 4 6th February 2014 04:50 AM
Bookshelf TL design kctess5 Full Range 7 6th February 2012 07:27 PM
Copyright ©1999-2019 diyAudio
