DIY 2-way design for a bookshelf
Old 21st January 2019, 04:27 AM   #11
LineSource is offline LineSource  United States
LineSource's Avatar
Troels Gravensen website has excellent cabinet construction tutorials.
Look over the Illuminator and SBAcoustics 61-NAC builds.
Illuminator-Monitor
-Illuminator Monitor cabinet will need to be adapted to these drivers.
-Moving the 2" port to the front baffle will allow box placement against the rear wall.
-The front port can be plugged for Qtc=0.57 sealed Bessel(min ripple) alignment.
-Metalized film capacitors like 400V Audyn
-Air core inductors AWG 15 or AWG 16 wire
-10W non-inductive resistors
-I used standard values to avoid higher cost of combining parts
---For high frequency SPL tuning: Purchase three 1-ohm resistors which can construct: 0.5-ohm, 0.66-ohm, 1-ohm, 1.5-ohm, 2-ohm, 3-ohm
?What will these speakers + crossover parts cost in Italy?
Old 21st January 2019, 05:46 AM   #12
kokoriantz is offline kokoriantz  Lebanon
I don't buy shoes without trying them, I don't buy speakers without listening. I advise you this small speaker that really amazed me .
YouTube
Ask him the detailers .
Old 21st January 2019, 02:20 PM   #13
zermak is offline zermak  Italy
@LineSource
Yes, it looks like he is a good loudspeakers' maker and I've read many of his two-ways builds by now.
Illuminator is obviously out of my budget and indeed I am orientend to his 61-NAC build but sadly the crossover section is unavalaible and I should run a simulation to figure it out somehow and I can't tell you the total parts cost without it (but I guess that for a pair I could stay under 400 euros).
And if you are wondering I have dropped the idea to make the "fast ref monitor" becasue of its limited up end.
@kokoriantz
I am not a fan of audio clips honestly and I don't see the point to listening to them considering that tons of factors are involved for a proper objective and subjective analysis. Plus I would like to have some decent bass and it seems the ProAC clone uses a 5 inch woofer (I know that it's not everything but a bigger cone surely helps, if properly tuned).
Old 21st January 2019, 09:59 PM   #14
I can't edit my message so I'll write a new post, sorry.
So I've looked up the costs for the materials with your crossover schematics (using two 22uF in parallel for the 40uF: couldn't find like a 22+18 and two 10uF in series for the woofer to have the 20uF value, or maybe I'll just opt for a single 22uF here also; all Audyn MKP QS) and for both speakers, wood excluded, I am at 425 euros with shipping.
Old 22nd January 2019, 03:02 AM   #15
LineSource's Avatar
midbass C1 can be 22uF
Ideally, tweeter C2 = 33uF is best. Does your store have 33uF?
1) Tuning series tweeter resistor for high frequency SPL : Purchase three 1-ohm resistors which can construct: 0.5-ohm, 0.66-ohm, 1-ohm, 1.5-ohm, 2-ohm, 3-ohm
-1.5 ohms models best
2) Baffle edge diffraction increases the on-axis SPL, and also increases off-axis energy spread into the room.
-How much you angle the front baffle toward the listener changes the amount of edge diffraction SPL heard.
---After you listener+room position your speakers, you can experiment with putting 0.5 -to- 2 ohm in series with midbass C1 to change the SPL heard by the listener around the diffraction freq range.
Google "Understanding Loudspeaker Cabinet Diffraction" By Jeff Bagby
If it only requires a simple cost table lookup, you can price the plastic cone SB17MFC35-8 midbass design posted earlier for comparison.
Old 22nd January 2019, 12:11 PM   #16
I understood your budget was 400euros . These scanspeak marvels cost 600$ x2 + crossover.
Old 22nd January 2019, 01:36 PM   #17
@LineSource
Yes, the store I am looking at has the 33uF 400V from Audyn (MKP QS series).
I've read about crossover tuning based on baffle dimension and so on but I will look it up for sure.
By the way I've simulated your crossover (using spl data on a "infinite baffle" from both speakers, with VituixCAD and its trace SPL tool) and it looks like the midwoofer underperform in the 1000Hz region (+-500Hz) before the cut-off frequency (which seems to be around 2000Hz).
I am just asking; have you tuned it considering the cabinet and so on?
@kokoriantz
Yes, indeed I am not considering them, he is suggesting to tune that cabinet design for SB Acoustics drivers, which he did, I suppose, listing me a possible XO build also.
With the crossover parts listed by LineSource as you can read above I am at 425 euros with shipping so I am in my budget with the SB Acoustic combo.
Old 22nd January 2019, 02:44 PM   #18
LineSource's Avatar
I started with the SBAcoustics 61-NAC cabinet measurements with these drivers and made small adjustments based upon simulations of the larger beveled baffle. The LR4 circuit on the SB17NAC35-4 is required to fully attenuate the 6kHz metal cone breakup. The BW3 circuit on the tweeter is adjusted to help compensate for the baffle effects.
Old 22nd January 2019, 02:56 PM   #19
Thank you for the explanations and yes I totally agree on LR4 considering the SPL of this particular midwoofer at mid-high frequencies because of the aluminium cone (the paper cone version is more flat indeed).
On tweeter side I can't say much, it looks good in both crossover versions (the optimized one with the infinite baffle SPL from my simulation and yours).
If you're curious I can show you the XO which it suggests me using available components from the store I will buy from and maybe you can run a simulation with it and tell me the response.
Old 22nd January 2019, 08:27 PM   #20
LineSource's Avatar
This is a better "general use" crossover.
Reduced tweeter SPL in order to provide about 3db bass baffle step.
Try these values in your simulation to confirm. You can compare the final tweeter + midwoofer SPL slopes with Troels SBAcoustics 61-NAC to confirm a very close match.
You can compare the SPL plot for your original "against the wall" goal vs. the SPL plot for this "general use" design more commonly selected.
DIY 2-way design for a bookshelfHide this!Advertise here!
looking for Morel bookshelf design msh1999 Multi-Way 11 8th March 2017 06:06 PM
Bookshelf Design for FE126 pcgab Full Range 11 1st November 2015 11:46 PM
need a crossover design for bookshelf arunpanchami Multi-Way 4 6th February 2014 04:50 AM
Bookshelf TL design kctess5 Full Range 7 6th February 2012 07:27 PM
Copyright ©1999-2019 diyAudio
