My first build and i want to do something near impossible i think ...
Old 16th January 2019, 12:29 PM   #21
NPower is offline NPower  Portugal
NPower's Avatar
Originally Posted by Meshach View Post
NPower ! what a beautiful speaker !!
Something has sparked my interest though, how did you make the flared horn to the left of the speaker ? Do you make the petals with a flair and then angle the edges ? Its a shape i just can't get my head around fabricating ...
thank you
Thanks Meshach
Well I'm not an expert and I don't want hijack your thread, but maybe I can give you some advice.
in fact, the petals were made with a mold and consist of three layers of 3 mm MDF.
The mold follows the Tractrix curve and has a 30 degree aperture. With these 30 degrees, I angle the edges (12 petals x 30 deg = 360 deg).
To assemble the 12 petals I use another rig.
What kind of crossover you intend to use (active / passive ) ??
Did you already saw "Volvotreter" web page ?
I think a lot of good advice's there.
Just keep us informed !
Performance is a state of mind !!
Old 16th January 2019, 03:02 PM   #22
LineSource is offline LineSource  United States
LineSource's Avatar
MEH - Multiple Entry Horns like the Synergy from Danley Sound produce coherent controlled directivity over a wide frequency range. There are several threads on DIY wood synergy horns covering different size and coverage patterns. You will also find DIY MEHs using the fiberglass SEOS-24 and SEOS-30, and ABS plastic 30" Klipsch K-402 horn with excellent measurements. Coaxial compression drivers like the BMS 4592-ND further simplify construction.
MEH meet your size and performance goals -- with a step forward in technology.
SEOS waveguides at Auto-Tech website
SEOS-24 - Horns by Auto-Tech
Klipsch sells the K-402 horn as part of their home cinema products.
A K-402-Based Full-Range Multiple-Entry Horn - Technical/Modifications - The Klipsch Audio Community
Old 16th January 2019, 03:23 PM   #23
Meshach is offline Meshach  Wales
After lots and lots of reading ... I have come to realise the first thing i need to do is buy measuring equipment then build some power supplies, then amps, then test them with my current speakers. Only question is do i make clones of Quad 909's or do i use Pass amps ?
Originally before i discovered DIY HiFi my plan was to buy quad 909's to replace my Cyrus amps.
After i have completely pickled my mind and completed the PSU's and amps I will contemplate making active crossovers for my Linn speakers, if I have success....
Then i will buy the table saw and start the woodworking and construction of my horns.
I will also contact W.A. and ask them if its possible i can have or buy the schematic of the TL15 cabinates to see if its possible to shrink them a little. Or look for a completely different design of T/L sub. ( i have not searched here yet and i'm still pondering with the idea of the vertical folded horn sub )
Anyway, it has dawned on me that i have alot to undertake and no where near enough knowledge to do it haha, so its going to be BIG learning curve for me and alot of questions for you dear people
So we will start again, this time starting with tools ... I understand i need.
Soldering iron
Oscillascope
Wave generator or something to create sign wave
Multi meter
Calibrated mic
Table saw
Router
Inclinometer ( for measuring the angle of the table saw blade with high accuracy )
Pillar drill
Can anyone think of anything else ? lolo
What i thought might be done in a month, in reality is going to take me maybe 18 months. Also the cost is not going to be what i thought and it's a little scary.
The whole outset of my project was to build a set of speakers that will easily out perform speakers that may be in the 20k/30k GBP region for 4k/6k GBP.
Now i understand its going to cost more like 10k by the time i finish, if i finish...
I will be straight with you all..... Is this worth doing or should i not even start ?
Does anyone have an idea of what 6x pass amps and PSU's, Active crossovers, Horns and subs sound like ? lolo
Thank you all for you'r time, I feel a little over whelmed but im still very egar to attempt my plan.
Meshch
Old 16th January 2019, 04:04 PM   #24
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
No, I would not advise to dive into building amps first. Instead get some more amplifiers so you can power all the drivers that you plan to incorporate, these need not be of the same topology or manufacturer, even chip amps could do. Start spending money with caution. Have a search on dsp crossovers, many find MiniDSP okay to work with. Be careful working with tablesaws. Sometimes it is far better to outsource this kind of a work.
Old 16th January 2019, 04:11 PM   #25
NPower's Avatar
Totally agree with Lojzek !
One thing I learned is that 50w is ok for TL, but way to much for horns.
Old 16th January 2019, 04:24 PM   #26
chris661 is offline chris661  United Kingdom
chris661's Avatar
I'm not sure I'd bother building the amps, but I'm a speaker guy.
FWIW, I just use some nice Powersoft amps (with DSP) for my stereo. They work, sound good, and there's endless tweak-ability, including linear phase (FIR) stuff. There's another rabbit hole for you.
Chris
Old 16th January 2019, 04:24 PM   #27
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
A speaker of that calibre will not reach anywhere near its potential unless you have some appropriate stuff in front of it.
I’ve not heard any new Quads, so i only have the Quad 303/405 to base any opinion on — the PASS amps are very good. All the way from the budget ACA kit up to the SITs which are examples of the very best amps there are. And all sorts in-between (and if price the only consideration some seriously expensive PASS amps).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th January 2019, 04:26 PM   #28
frugal-phile(tm)
planet10's Avatar
+1
+1
dave
Old 16th January 2019, 05:46 PM   #29
Ok, assembly of electrical circuits and soldering i have no problem with. testing is another thing ..
As for the table saw, don't worry, i have experience in woodworking and metalwork. ( Another reason for the table saw is i plan to make some furniture from hardwood in the future. I did have access to a fully stocked carpentry workshop but as i plan to do all of this in Spain i will need to buy my own tools and make a workshop )
When i say Pass amp's, what i think i really mean is the First Watt amps that come as kits but are designed by Mr Pass ( ? )
As a child and reading hifi choice over the years the amps i have always been drawn to are Cyrus, Quad and Meridian. Of which over the years i have heard all three. The dream was to own something from Krell lol.
I will indeed scour ebay and look for amps, also the recommendations you have given here. I understand this is going to be a long process and i'm sorry if ask things that might seem stupid to the people of the forum but in all honesty i have no real clue on how to achieve what i want apart from being able to fabricate to a nice finish, the cabinates, horns and stands.
Side question lolo...
I have two Cyrus stereo power amps running as monoblocks. After talking with you lot, would i not be better running the amps mono but use the stereo outputs to go the crossovers and split the bass from the mid and treble ?
.............................--L-- Treble / Mid
............--L--amp--{
............................--R-- Bass
--DAC--{
............--R--amp--{
.............................--R-- Bass
Please ignore the ( ..... ) i could not use tab to space everything out, hope I make sense haha
Meshach
Old 16th January 2019, 05:55 PM   #30
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Have you heard any horn speakers?
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
My first build and i want to do something near impossible i think ...Hide this!Advertise here!
Is it that impossible? Nosian Pass Labs 9 5th March 2015 12:00 AM
mission impossible & bdm47 Multi-Way 1 26th May 2012 07:42 PM
Jvc RC-EZ51 impossible to buy Nomdi Swap Meet 5 1st October 2011 10:46 AM
Impossible to find pot??? highspeedsentry Parts 20 8th July 2011 01:32 AM
Copyright ©1999-2019 diyAudio
