How to wire 4 ohm speaker and tweeter to a 4ohm 150w RMS amplifier?
Old 11th January 2019, 08:22 AM   #1
Nived is offline Nived
Default How to wire 4 ohm speaker and tweeter to a 4ohm 150w RMS amplifier?
Hi Friends,
Iam planning to build a two way speaker system for my 150W RMS 4ohm amplifier. My driver configs are; 8inch woofer of 50W RMS @4ohms and Piezo horn tweeter of 40W RMS @4/8ohms (dnt know why it is marked as 4/8). How can i wire these two ? In series ? or if i need 4ohms nominal from these two can i use a 8ohm woofer instead of 4ohm?
does this system requires a two way crossover compulsory or can i wire it directly in parallel or series ?
Amplifier ratings : 150W RMS per channel @ 4ohms
Woofer : 4ohm, 50W RMS, 8inch
Tweeter : 4/8ohms, 40W RMS, Piezo horn tweeter 7"x3"
Old 11th January 2019, 09:23 AM   #2
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Your 150W RMS amplifier will destroy your 50W RMS woofer.
Upgrade that and we continue talking.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 11th January 2019, 10:29 AM   #3
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
The drivers will present different loads at different frequencies due to the crossover.
I would just wire them in parallel.
But I would be careful using such a powerful amp with lesser speakers.
PCBCAD51 download or CDROM 2019 version out now http://www.murtonpikesystems.co.uk
Old 11th January 2019, 10:43 AM   #4
TBTL is offline TBTL  Germany
Wiring in parallel should work. If the amplifier starts oscillating, adding a series resistor to the piezo will help maintain amplifier stability. Something from 10 - 22 ohms will work. Then wire the woofer and [piezo + resistor] in parallel.
Old 11th January 2019, 11:28 AM   #5
audfrknaveen is offline audfrknaveen  India
so you people are saying crossover is not a compulsion !!!
Does it mean all low freq. will also go to tweeter and all high freq. also go to woofer.
Isn't there any risk of damage ???
I don't know the details, but some one used a simple capacitor as a crossover.
Any thoughts on this please .....
Old 11th January 2019, 12:19 PM   #6
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
...as a piezo tweeter is a capacitative load, the capacitor used as HP is not useful- but it works, however. And, yes, the problematics of having a woofer and a tweeter ( and, often, a midrange driver ) working together is already solved with the network of components ( L-R-C ) called crossover
Everything under and above heaven is in utter chaos
mare monstrum
Old 11th January 2019, 01:41 PM   #7
JMFahey's Avatar
Yes, crossovers are needed, no doubt, but in this particular case itīs common practice not to *add* one to the one thatīs already there.
The woofer (any voice coil speaker by the way) does already have a series inductor, the voice coil inductance, which makes it steadily rise impedance above about 1kHz .
And the piezo tweeter IS a capacitor.
So much so that , as recommended above, itīs good practice to add a series resistor, anything from 10 to 50 ohm, 2W.
Its impedance within the Audio band is so high that in practice "itīs not there" and the speaker cabinet can be considered same impedance as the woofer.
My problem is not with that, but woofer power handling.
In any case, we donīt know either the speaker nor the amp involved, so ....
Old 11th January 2019, 04:03 PM   #8
Galu is offline Galu  Scotland
Piezo tweeter crossovers are not compulsory, but are recommended for the reasons explained here:
Frugal-phile | Piezo Tweeter Crossovers | J Risch
Old 12th January 2019, 06:50 AM   #9
Is it ok in wiring both 4ohm woofer and 4ohm tweeter in parallel ? chance for any total impedence issues ? bcoz my amp's impedence is also 4ohms.
Old 12th January 2019, 06:57 AM   #10
you mean wiring 4ohm woofer + 4ohm piezo tweeter (with a resistor in series) should work. right ? my amp's impedence is also 4ohms. so is there any chance for total impedence issues ? i mean 2 4ohm drivers in parallel reduces to 2ohm right...
How to wire 4 ohm speaker and tweeter to a 4ohm 150w RMS amplifier?Hide this!Advertise here!
Advice for amp board with 4ohm max 150W 88dB speakers atamgp Chip Amps 8 9th November 2018 02:28 PM
Building my own noninductive 8R 150W load using wire wound resistors Mark Johnson Parts 62 24th September 2017 03:36 PM
Long wire run 4ohm speakers. 100-150 feet of wire Richard_James PA Systems 45 24th May 2017 04:49 AM
Visaton FRS 8 4ohm use as a tweeter charlie2 Multi-Way 13 19th June 2015 03:03 PM
4ohm Tweeter & 8 ohm woofer Juggy Multi-Way 2 9th December 2008 02:14 PM
Copyright ©1999-2019 diyAudio
