How to wire 4 ohm speaker and tweeter to a 4ohm 150w RMS amplifier?
Old 12th January 2019, 07:52 AM   #11
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Originally Posted by Nived View Post
you mean wiring 4ohm woofer + 4ohm piezo tweeter (with a resistor in series) should work. right ? my amp's impedence is also 4ohms. so is there any chance for total impedence issues ? i mean 2 4ohm drivers in parallel reduces to 2ohm right...
Have you *read* the answers above?
Besides:
That applies to standard drivers, but a "4 ohm" Piezo is NOT 4 ohm.
Post the specific Piezo datasheet or specs link for further discussion.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 12th January 2019, 08:06 AM   #12
Nived is offline Nived
Originally Posted by nigelwright7557 View Post
The drivers will present different loads at different frequencies due to the crossover.
I would just wire them in parallel.
But I would be careful using such a powerful amp with lesser speakers.
Is it ok in wiring both 4ohm woofer and 4ohm tweeter in parallel ? chance for any total impedence issues ? bcoz my amp's impedence is also 4ohms.
Old 12th January 2019, 01:15 PM   #13
Galu is offline Galu  Scotland
The simple answer is yes, it is OK to wire them in parallel provided you are using a piezo tweeter. The total impedance will be 4 ohm.
However, a simple parallel arrangement it is not optimum. I suggest you read the information that has already been supplied, in particular:
Frugal-phile | Piezo Tweeter Crossovers | J Risch
How to wire 4 ohm speaker and tweeter to a 4ohm 150w RMS amplifier?Hide this!Advertise here!
Advice for amp board with 4ohm max 150W 88dB speakers atamgp Chip Amps 8 9th November 2018 02:28 PM
Building my own noninductive 8R 150W load using wire wound resistors Mark Johnson Parts 62 24th September 2017 03:36 PM
Long wire run 4ohm speakers. 100-150 feet of wire Richard_James PA Systems 45 24th May 2017 04:49 AM
Visaton FRS 8 4ohm use as a tweeter charlie2 Multi-Way 13 19th June 2015 03:03 PM
4ohm Tweeter & 8 ohm woofer Juggy Multi-Way 2 9th December 2008 02:14 PM
Copyright ©1999-2019 diyAudio
