Sonus Faber Extrema clone
Old 8th January 2019, 11:50 AM   #1
drf24 is offline drf24  United States
Default Sonus Faber Extrema clone
I know this has been on here before but I am at a point that I need some help.
I have drawn the SF Extremas in AutoCAD using photos I scaled from known dimensions to get the general shape as close to the original as possible. I have sourced a set of KEF B139 for the passive radiators and a set of Chinese cloned Dynaudio tweeters.
The cabinet will be a laminate of 3/4" MDF with hardwood sides. I have had the templates cut from 5/16" aluminum plate which will allow me to cut the general shape of each laminate piece and then use a flush bit on my router to get them to the exact shape. Each template has 1/4" locating holes to be drilled and fitted with 1" dowels. The front plate that will eventually be wrapped in leather gives me the freedom to try different drivers. The calculated internal volume is 20 liters, just like the original.
Where I need help is the woofer selection. There are so many to choose from it is a bit overwhelming.
Thank you in advance
Dean
Old 8th January 2019, 12:12 PM   #2
denibeni is online now denibeni  Hungary
Why not to buy Chinese tweeters?
Old 8th January 2019, 12:30 PM   #3
Old 8th January 2019, 01:10 PM   #4
This is just one example. Nowadays tweeters are delicate devices, i don't think it's worth to buy a cheap chinese clone if sound quality is priority.
Old 8th January 2019, 01:19 PM   #5
Trying a new link cant seem to get it to work.Click the image to open in full size.
Old 8th January 2019, 01:21 PM   #6
PeteMcK is offline PeteMcK
Peerless Nomex woofers
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 8th January 2019, 01:23 PM   #7
Thanks, I will give them a look.
Old 8th January 2019, 03:07 PM   #8
manchambo is offline manchambo  United States
Depending on the shape of those old passive radiators you got, you might also consider the se SB radiators: SB Acoustics SB15SFCR-00 5x8 Passive Radiator
Old 8th January 2019, 03:29 PM   #9
I already have the KEF B139 woofers and the clone Dynaudio tweeters.
I found a set of the B139 woofers in excellent condition.
Old 8th January 2019, 04:14 PM   #10
raelman is offline raelman  Spain
Really interested in thie project. I was trying to do it some tiem ago and I left because the big difficult on the wood shape.
Sonus Faber Extrema cloneHide this!Advertise here!
Sonus Faber Extrema bfard Multi-Way 119 15th August 2012 06:36 PM
Sonus Faber Cremona Clone audioPT Multi-Way 31 27th May 2010 05:26 PM
Sonus Faber Minima Clone sianturi Multi-Way 2 12th August 2002 08:16 AM
Copyright ©1999-2019 diyAudio
