I am testing out the Beston RT002A ribbon tweeter in my speakers that I have put together. There is about a 4db spike at 15k. Do you think I should try a notch filter here, or could it be caused from the tweeter not being flush mounted yet. It is about a half inch flush from the baffle. This link of someone who has tested the tweeter also shows the spike.
Test Bench: Beston Technology RT002A Ribbon Tweeter | audioXpress
The tweeter crossover is 3.3uf .10mh 10uf. I am kinda concerned of the slope of the tweeter. I wish it more around 24db.
Yes I will flush mount the tweeter but I have a feeling that will not fix anything.
A rise in the UHF (ultra-high-frequency) range makes me suspect the measurement mic.
Is your second attachment only the tweeter output?
Why is it running flat to below 400Hz?
Chris
Yes that is tweeter only. I dont understand your question, It should be flat right? It starts to drop off at 30hz.
