How much low frequency for the satellites of a 5.1 HT?
Old 7th January 2019, 08:51 PM   #21
bentoronto is offline bentoronto  Canada
Originally Posted by cbdb View Post
Most HT recievers have dsp settings for "steering" the bass away from the full range speakers to the sub. Some even let you set the xover freqs.
See my previous reply. Yes, my A/V receiver kind of vaguely says all those nice things vaguely.
Maybe because A/V sound is so cooked, just doesn't matter about xo point, slopes, distortion, etc.
B.
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio (also, see recent post with data on a 17-foot labyrinth sub)
Old 7th January 2019, 09:34 PM   #22
Robh3606 is offline Robh3606  United States
Robh3606's Avatar
My A/V amp talks that way but just still a wild guess at how the signals are cut up to the speakers in the cheap modules inside the amp.
Depends I can adjust crossover frequency for 40-200Hz in 10Hz increments and pick the slope of either 12db or 24db. It should all be clearly laid out. I am using a Pre Processor with discrete amps so I may have more flexibility put it shouldn't be that different. I have a dual use music and HT system and my mains are an active 4 way system and with the processor I can go completely analog to those mains in a reference stereo mode with no digital processing.
Rob
"I could be arguing in my spare time"
Old 11th January 2019, 07:05 PM   #23
morgot9999 is offline morgot9999  Romania
morgot9999's Avatar
Thank you all for your suggestions.
As said before, as satellite channels are full-range, have 3 options, from the simple to complex:
1) single full range driver (6"?) focusing on voice frequency range
2) single coaxial driver
3) two way 6"-8"+ 1" with crossover
Old 11th January 2019, 10:02 PM   #24
Jeff Cook is offline Jeff Cook
For my in-progress small room home theater build, for surrounds I am targeting reference levels with -3dB point no higher than 60Hz.
I don't have final drivers selected yet (too early), but I am sizing the in-wall backer boxes (part of the soundproof shell) so that I can use a Faital 8HX200 8" coaxial for 200/300Hz+ and an AE TD12 for 50/60-300Hz.
How much low frequency for the satellites of a 5.1 HT?Hide this!Advertise here!
Satellites for new 5.1 system aramosfet Multi-Way 8 11th June 2012 04:33 PM
satellites+sub? testarossa2k Full Range 2 14th April 2007 04:30 PM
OB Satellites ralph-bway Multi-Way 2 21st November 2005 03:00 AM
satellites for marble sub Artmaster Multi-Way 0 15th November 2004 01:17 PM
F3 for HT satellites dooper Multi-Way 3 7th February 2004 05:14 AM
Copyright ©1999-2019 diyAudio
