Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Multi-Way Conventional loudspeakers with crossovers |
#31 |
You should move those bushes in pots on the pavement between the speaker and mic when measuring. Tile floor gives "perfect reflection" now.
#32 | |
![]() The mic is on the little table in front of the laptop. That seems right to me. I experimented with stuff to prevent ground bounce, and found that that made the notch in response worse (more complex).
This edit signature thingy is seriously hard to find |
#33 |
Pots etc. are diffusers, pillows etc. would be dampers. Anyway sounds like you have recognized the floor bounce 😄
#34 |
Black/yellow = sealed box, on axis vs 30 degrees off axis.
Black/blue = perforated box, on axis vs 30 degrees off axis. Not much difference, but the perforated box is slightly 'tidier' off axis. One has to read around the 2 big ground bounce notches... maybe next time I'll do ground plane measurements.
#35 |
0 vs 150 degrees off axis.
The perforated box has a lot more rear rejection @ 100Hz, but for a 400Hz or 500Hz crossover, this is not a great outcome.
#36 |
0 vs 90 degrees off axis. This is where the perforated box shines.
...so it would be throwing a bit less off-axis sound into the room.
This edit signature thingy is seriously hard to find Last edited by hollowboy; 18th January 2019 at 09:58 AM. Reason: slightly wonky image |
#37 |
Looks like REW? I love it but it can't draw directivity graphics or count DI. But taking measurements at 10¤ steps and overlaying all of the 0-90¤ (and 90-180¤ separately) would reveal the directivity "shape". Set IR gating to 6, 12, 20, 60 etc. ms and look at same measurements again. I have found 20ms and 1/12 smoothing best and then first reflections can be detected easily.
This is from ARTA and from this thread DSP midrange directivity control aka kinda cardioid ![]() Last edited by Juhazi; 18th January 2019 at 10:19 AM. |
#38 |
#39 |
Time to buy a six wheeled stair climbing hand truck. That will make your life a lot easier.
Don't Procrastinate....Just Do It! |
#40 | |
To finally mount the top sections in-situ, I think beers, BBQ and make a day of it with a few mates. |
Thread | Thread Starter | Forum | Replies | Last Post |
New to hornresponse help w/ 50/60-400hz J-horn | hum4god | Multi-Way | 6 | 20th October 2015 06:35 PM |
Another Home Synergy Concept - matching pattern control frequencies for asymmetric ho | bwaslo | Multi-Way | 19 | 16th February 2014 03:27 AM |
B&C DE25-8 CD/Stereolab 400Hz horn | Hylle | Multi-Way | 11 | 7th March 2013 01:46 PM |
Stereo Lab 400hz 1" horns | winslow | Swap Meet | 14 | 21st July 2009 11:40 AM |
best PURE midrange (400hz-->) | thadman | Multi-Way | 48 | 12th August 2007 03:35 PM |
New To Site? | Need Help? |
