Can some one please draw a me a xover
Old 4th January 2019, 06:07 PM   #21
turk 182 is offline turk 182  Canada
ok seeing as how you don't know what "point to point" means and reading the schematic is not going to happen i take it you would need a lot of hand holding to get you through this, correct?
you must at least have some tools otherwise you would not have been able to dismantle it to this point.
Old 4th January 2019, 06:21 PM   #22
youngie is offline youngie  United Kingdom
I do have all the tools maybe itís best I never if you no what I mean. Thank you for your reply. I can do it I know I can but with help. Where it starts and finishís. I know what everyone is thinking. I would too.
Old 4th January 2019, 06:26 PM   #23
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
The simplest thing to do would be to lay out the components exactly as in the circuit diagram on a thin piece of plywood with holes drilled so you can secure them with cable ties. Can you do that?
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 4th January 2019, 06:36 PM   #24
Galu is offline Galu  Scotland
scottjoplin just beat me to it!
The attached photo shows the sort of thing we mean by 'point to point' wiring.
You lay out the components the way they are placed in the circuit diagram then solder them together with copper wire.
Perhaps you have a more practical friend who can assist you?
Old 4th January 2019, 06:37 PM   #25
Lojzek is online now Lojzek  Croatia
Lojzek's Avatar
Hey there lee,
I was wondering if you still have the original boards, damaged or not and what exact parts do you have at your disposal?
"Immer wenn du denkst es geht nicht mehr, kommt irgendwo ein Lichtlein her."
Old 4th January 2019, 06:45 PM   #26
system7 is offline system7  United Kingdom
system7's Avatar
There's actually two crossover boards:
The woofer gets one too:
Luke must be Mike Creek's boy. I met Mike Creek years back. British HiFi was conducted in the front lounge and garage of suburban homes then. I was doing amps and differential preamps back then. He wanted a guy to see an FM tuner into production. I had to be honest and admit tuners weren't my bag. But a charming man. He gave me a schematic of the famous old Creek amplifier. It was unusual in having a single rail power supply and an output capacitor. I gave him a schematic for a balanced line phono preamp.
Best Regards from Steve in Portsmouth, UK.
Old 4th January 2019, 06:58 PM   #27
Post #12 mentions this - fortunately the lower woofer board is intact!
Old 4th January 2019, 08:20 PM   #28
Thank you this is how they should be laid out. But I donít have the upper and tweeter and the in connections many thanks lee
File Type: jpg 6926744E-6627-487A-B76B-966A24E34D5C.jpg (540.7 KB, 120 views)
Old 7th January 2019, 07:17 PM   #29
chrisng is offline chrisng  United States
Use some Euro style connectors cut to size and wire it to schematic:
Old 7th January 2019, 07:22 PM   #30
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
Or just solder down some wires where the foil used to be. That's all the foil does, it connects components and leads to each other.
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Can some one please draw a me a xoverHide this!Advertise here!
Current Draw of CJ ART?? Tubenstein Tubes / Valves 1 22nd December 2015 08:16 AM
Current Draw microsim444 Power Supplies 0 17th December 2009 08:36 PM
can someone draw a PCB for a SMPS for me? lorik199 Power Supplies 11 8th March 2009 08:40 PM
re-draw the I/V sch of Krell SBP-32X DAC X.G. Digital Source 21 13th March 2007 08:19 AM
LM3886 and active xover - how to draw groundplane? AndersZ Chip Amps 16 6th December 2003 10:36 AM
Copyright ©1999-2019 diyAudio
