Yamaha NS 1000 - Drivers Upgrade/Replacement
Old 5th September 2019, 10:13 PM   #21
srinath is offline srinath  United States
I've bought those, but I have never done a VC before, yea Foams I have by the 1000, but no VC yet.
Old 11th September 2019, 02:48 PM   #22
Eagerly awaiting my VC's, but in the meantime imagining a rig to align these, one that will accept a slow curing epoxy in the middle.
I have come up with a steel channel about 1/2" wider than the widest point of the magnet - that's 6" - channel could be even wider, 7" or 8" even with a bolt hole and a nut welded on the inside where if you install a bolt, you would push the plate that's attached to the basket only. So the process would be, put the 90 minute or whatever time epoxy, put the basket over the cone, lining up the VC as well as you can, and pinch or not, put them together. Then use the bolt to push it to where it wont rub and grind the VC.
I'm replacing the VC after doing this but I need to get it to not rub in the first place, I can take up a bit of lopsided fit up when I glue the VC I guess, but I'd rather make a rig to get it spot on. Then let it cure, then replace the VC.
Thanks.
Srinath.
Old 11th September 2019, 04:45 PM   #23
Or a brake drum for a car could work.
Thanks.
Srinath.
Old 27th September 2019, 02:04 PM   #24
My VC's don't fit, they are slightly too small. What did these have ? a 68mm VC, cos I got 66mm and it wont fit and its almost like it can be forced on but not fit of its own free will.
If I take off the copper cap on the pole piece, it will fit. What does that cap do ?
Thanks.
Srinath.
Yamaha NS 1000 - Drivers Upgrade/ReplacementHide this!Advertise here!
Driver Replacement for Yamaha Subwoofer Gwho Subwoofers 19 24th January 2019 12:55 AM
Infinity RS-5000 midrange driver replacement. redrooster Multi-Way 9 28th March 2018 01:09 PM
Woofer or Compression Driver Handling the Midrange? jamesdb Multi-Way 28 23rd June 2014 05:36 PM
Driver replacement/upgrade? hapinoregon Full Range 4 8th January 2013 07:46 PM
Distance between Woofer and Midrange driver LageB Multi-Way 9 21st August 2003 05:53 AM
Copyright ©1999-2019 diyAudio
