I have tested my crossover and I'm very happy with the performance. I have layed out the components on the crossover board but I have yet to determine how I'm going to neatly connect the wires to ground.
I would like to run a grounding block of some type down the center of the board and solder the 6 ground wires to it.
I haven't found any type of terminal strip I'm happy with for this purpose.
Any ideas?
Any ideas?
I use these cheap as chips solder lugs. Down the back where the tags go through the backing, I solder a length of the same wire I use for internal wiring. Alternatively you can use the components themselves to make the bridge; they usually come with extra long lead out wires.
Usually solder down all 5 for the earth, but you can solder combinations, such as 2 and a 3 for other connections.
I then screw these to a wooden plate which I can glue the components to.
