I'm wondering how I can reduce its volume by a dB or two.
Try a 1R 5W resistor in series with the tweeter.
is a 1 ohm resistor really going to drop it much? im not sure if I have a 1 ohm resistor around.
It's a 4 ohm tweeter, yes? That's about -2dB.
Here is the calculation if you have an 8 ohm supertweeter:
If we put 2 ohm in series with an 8 ohm tweeter and assume a 10V drive voltage then the current will be V/R = 10/10 = 1A
The voltage across the tweeter will be I x R = 1 x 8 = 8V
Before adding the resistor, the voltage across the tweeter was 10V
So the ratio of new voltage to old voltage = 8/10 = 0.8V
This equals a reduction of 2dB
ok its 4 ohms
I found some that measure like 1.6-something and they seem to work okay
but its still pretty crisp O.O
Then try two of your resisters in series for each tweeter.
Two dB would still be a fairly small amount of attenuation.
only have two of them.
What else ya got?
Care to share your solution with us?ok I used the resistors and it definitely helped!
- reduce volume of Niobium micro dome super tweeter slightly?
