Switches: What amperage? Wire: What gauge?
Old Today, 03:05 AM   #1
Cableaddict is offline Cableaddict
Default Switches: What amperage? Wire: What gauge?
I'm about to replace some barrier strips on my live Mid-high speakers with Neutricks and a 4-pole switch. (The switch bypasses one internal crossover)
I'm wondering how high I need to go in the switches amperage rating, to not worry about any losses. I assume I don't need much, but wanted to check and be sure.
The speakers take a max of 1100w @ 8 ohms.
And also, what gauge wire is enough, for internal runs less than one foot?
- Thanks.
Old Today, 03:38 AM   #2
rayma is offline rayma  United States
with Neutricks and a 4-pole switch. what gauge wire is enough
SpeakONs are rated for 50A, so there's your maximum needed switch rating.
They take up to #10 wire, so there's your maximum needed wire size.
Old Today, 05:32 AM   #3
Thanks. - but those aren't MY numbers!
I'm looking for the minimum values I can safely use, for low cost, low weight, and low footprint. I doubt a 50a 4-pole switch even exists.
Neutricks have to handle the most powerful transfers possible, for any speaker made.
Again, my speakers, pertinent to this query, handle a maximum of 1,000w.
And I've never seen internal wiring anywhere near 10 gauge. That would not be fun to solder.
I'll probably use 16 gauge, but thought I'd check here first.
Old Today, 08:21 AM   #4
avtech23 is offline avtech23  Australia
Certifiably addicted to DIY.
avtech23's Avatar
Neutrik is the brand (they make SpeakOn, powerCon etc).
Which neutrik connector are you planning to use in particular?
Google tells me: The theoretical maximum current given by P = I^2 / R is sqrt(1000W / 8 ohm) = 11.2A
The ever growing project list.. :NAP140 Clone, NAD 3020i & 3225PE, JLH1969, TDA2050, Fender 5F2A Princeton, NE5532 Preamp | : VSQC Phunk Style, Retro 50W | : Apex AX-14 | SHPA | TGM-10 | TDA7265 (Last in line)...maybe
Old Today, 11:06 AM   #5
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
There is a typo in the first part of the equation, although result still correct.
"Immer wenn du denkst es geht nicht mehr, kommt irgendwo ein Lichtlein her."
Old Today, 11:11 AM   #6
avtech23's Avatar
Spot on, I copied it on my phone and didn't even notice!
P=I^2 R
I=SQRT(P/R)
Old Today, 12:16 PM   #7
MAAC0 is offline MAAC0  Portugal
On the innards of my PA speakers I use 2.5mm2 Wire. For Subs 4mm2.
For 1000W You are looking for 15 Amps wire / Switches.
Old Today, 12:55 PM   #8
bentoronto is offline bentoronto  Canada
Do you plan on doing the switch during loud or soft passages?
B.
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio (also, see recent post with data on a 17-foot labyrinth sub)
Old Today, 02:47 PM   #9
mark100 is offline mark100  United States
I use this one for switching passives in and out because it has 4 poles.
I also use it to handle 4000w to subs (I put a small DC voltage on subs when not in use)
Member Login
Old Today, 03:03 PM   #10
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
You easily can get away with using Carling 254–73 4 pole screw-terminal switches. 15 amp capacity, not overly expensive. Less than twenty bucks at Mouser. The wire is equally flexible: 16 gauge tinned stranded copper is best, tho' "naked stranded copper" (i.e. without tinning) is fine too. Personally, I'd also use crimp-on lugs on the wire, available at any hardware store.
To give some idea how much power is lost not going to 10 gauge, not getting a huge 50 amp million dollar switch… its all about Ω.
P = I² R
R ≈ 4 Ω
P ≈ 1200 watts … therefore
I = √( 1200 ÷ 4 )
I = 17 amps
Note that those would be peak amps, not average ones. For sound material being blasted at the full capacity of the speakers and amplifier.
however, if again you look at the formula, and express it slightly differently:
P = I²( R1 + R2 ) where
R1 ≈ 4 Ω (speakers)
R2 ≈ 0.05 Ω (switch + imperfect added wiring)
You notice that the power "lost" is only related to the ratio of the speakers' impedance to the added switch-and-wire resistance of making your change. And that … in this example … is 0.05 ÷ 4 → 0.0125 or basically 1% of the power.
Acoustically 1% is 20 log10( 1 - 0.0125 ) → –0.1 dB.
Turns out that we cannot hear –0.1 dB power drop. At all. 1 dB, yes. 0.1 dB, no.
Just saying,
GoatGuy
John Curl's Golden Rule…: 100 kHz bandwidth, 3 μs risetime, 100 W mean output, 100 V/μs slew rate, 2 Ω dynamic load, 20 amp min current source/sink
Switches: What amperage? Wire: What gauge?Hide this!Advertise here!
What wire gauge?! Need help! 3wayaddict Subwoofers 53 30th January 2018 12:37 AM
What GAUGE wire???? kittygirl Class D 5 15th July 2012 01:50 PM
What's the best wire gauge to run to the HU? phrarod Car Audio 14 14th June 2008 01:35 AM
fet wire gauge MikeZ Pass Labs 2 21st April 2004 01:43 PM
Wire AWG & Amperage Capacity KevinLee Parts 12 10th December 2003 03:42 AM
