Weird noise inside Heco Superior 940
Old 9th December 2018, 09:32 PM   #1
Buehgemeiste is offline Buehgemeiste
Default Weird noise inside Heco Superior 940
Today i purchased a pair of good old Heco Superior 940
I listened to them before the purchase and they sounded great
Whlie driving them home in my car i heard a weird noise coming from the loudspeakers.
It sounded like something dropped inside one of the boxes.
When i carried them from the car inside the house the exact same noise repeated in both cabinets.
It was like a rattle and i imagine something dropped inside the boxes.
Now i'm uncertain what the reason for those noises were and what to do.
Is it possible that the x-o loosend and dropped?
What else could have dropped?
Where should the x-o be located in those cabinets?
Should i simply connect an amp and try the speakers?
Should i remove one woofer (which) and take a look inside?
Old 9th December 2018, 09:43 PM   #2
charlie2 is offline charlie2  England
Do not connect them up until rattle is resolved
Take out a driver and look in side n feel if nothing obvious shake and bang the cabinets with palm of hand
Old 9th December 2018, 10:57 PM   #3
ok.
i guess i should remove the lower of the two woofers.
does anybody own a plan, that shows the inside layout of the cabinets.
did anybody here ever open those speakers?
Old Yesterday, 12:01 AM   #4
Galu is offline Galu  Scotland
The two woofers are isolated from each other in separate chambers.
Be prepared to remove both woofers and probably the midrange and tweeter as well.
Old Yesterday, 01:38 AM   #5
avtech23 is offline avtech23  Australia
Certifiably addicted to DIY.
avtech23's Avatar
I recently caught my little boy feeding wooden toys into the port of my subwoofer. You'd be surprised at what you might find inside
Shouldn't be too hard to pop the drivers out and fish out whatever might be loose.
The ever growing project list.. :NAP140 Clone, NAD 3020i & 3225PE, JLH1969, TDA2050, Fender 5F2A Princeton, NE5532 Preamp | : VSQC Phunk Style, Retro 50W | : Apex AX-14 | SHPA | TGM-10 | TDA7265 (Last in line)...maybe
Old Yesterday, 02:40 AM   #6
phivates is offline phivates  United States
The inductor for the lf driver pulled loose from the crossover board it was hot-glued to. Happens a lot on cheap stuff that endures rough handling unforeseen by the hurried assemblers not permitted to add a ty-wrap, say. You can fix it.
Looks like these were not so cheap. Still, rough handling can cause glued bits to separate.
Old Yesterday, 02:54 AM   #7
tsmith1315 is online now tsmith1315  United States
tsmith1315's Avatar
The Heco products (80's -90's) I have seen or dealt with have been very good quality and not very cheap.
Tim
Old Yesterday, 05:55 AM   #8
That's why i don't want to touch anything if not necessary.
That's the kind of info i was hoping for.
Any idea where the crossover is sitting?
Luckily those are closed boxes.
I donīt think it will be hard.
But to me loudspeakers like mine might very well be exhibited in a museum.
I don't want to touch the ribbings or anything else, because replacement parts are hard to get.
I don't even like the screws to look used...
Old Yesterday, 12:40 PM   #9
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Are there any chances to remove the back plane for to give you complete insight over the innards?
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old Yesterday, 03:20 PM   #10
Best regards!
No chance.
I removed the big woofers.
In both chambers i found big round magnets.
It seems those magnets were originally glued to the back of the drivers.
Is there anything wrong with using superglue for the repair?
Weird noise inside Heco Superior 940Hide this!Advertise here!
Help diagnosing weird noise RhythMick Tubes / Valves 39 2nd November 2017 12:21 PM
Musical Fidelity E1: weird noise darkpeak Solid State 4 13th June 2013 07:38 AM
22k capacitor? and another weird one pictured inside brilliantblue Solid State 8 13th August 2012 02:38 PM
heco superior presto 750 mschwilson Multi-Way 0 6th December 2006 07:34 PM
Weird, Less noise with more voltage. dkemppai Solid State 17 14th January 2003 02:46 PM
