Old 3rd February 2019, 08:45 AM   #71
beardman is offline beardman  Denmark
Really fine work..not bad with the Rover cnc...i tried at first to countersink my speaker unit
but it was not good with the massive ash tree i used at first (very unstable front,even with
30mm) much better with 30mm MDF without countersink
Old 5th February 2019, 08:38 AM   #72
Coasttocoast is offline Coasttocoast  United States
Originally Posted by Juhazi View Post
I am excited to see how you install internal braces and subenclosúre for the mid!
The-Loudspeaker
Juhazi, thanks for following along. Braces, which will include the sub enclosure for the mid, crossover, and plate amp are next up. I have already pre-cut the pieces. I hope I have a plan!
Babelfish J as Aleph 2, McIntosh C2300, RAKK DAC Mark IV Extreme, Oppo UDP-203 DVD/CD, Custom SP10 MKII/SME 312s/Koetsu Urushi Black, Magna Mano streamer, Ekta Grande speakers, DIY 13" ScanSpeak sub's w/Hypex Fusion 501’s, Transparent Ultra cables.
Old 5th February 2019, 08:46 AM   #73
Thanks! And I understand about the countersinking.
I’m using 2 layers of 19mm material, countersinking the 18” goes almost all the way through the first layer. But for the look I’m going for I needed them flush.
Still trying to find a vendor to source some custom trim rings for the 10” and 18” drivers. Anyone have a recommendation?
Old 8th February 2019, 07:18 AM   #74
Got a little mid week shop time in. The cabinet shop has been really busy for a while, now the guys are pretty much back to leaving at 2:30, so worthwhile for me to get maybe 3 hours in and not be in their way.
Finished up the braces, except for trimming to fit. Each cabinet gets 3 horizontal braces, one on each side of the 10”, which also makes its sub cabinet, and one centered on the 18”.
But main item of the day was putting the 1 1/2” roundover on both vertical sides of the fronts. A good amount of material to cut away, very messy. Kind of hard at this point to see in pics, but really softens up the look. Glad to get this out of the way, and not have to be covered in Medex dust all day doing this on Saturday morning.
This is the biggest bit you can fit into a router, next size up would be a custom bit in a shaper, FYI.
To show sense of size I took a pick with a 55 gallon drum for reference.
6D6F0733-12D7-4841-90FF-07E0320558C4.jpg82528487-5936-4368-A628-AEA2AECD258D.jpg2B1377A9-2CEE-443B-82B8-3CC8B4DD671A.jpg
Old 10th February 2019, 07:38 AM   #75
I had the run of the shop again today. Made some good progress
Started out cutting the openings in the second layer of the front baffle. Cut it close with a jig-saw, then used a 1/4” router bit with a roller on the end that traced the CNC cut in the first layer. Now the “box” is complete. All finished Maple interior.
Then after fitting and labeling each of the braces I gave them a quick sand with 220 grit. Then into the paint booth for a couple coats of high solids, semi-gloss clear. I’m making every effort to minimize humidity from being able to wreck havoc with the wood.
The clear is dry to the touch in 25 mins, so then started final assembly. I also caulked all the corners with polyurethane.
Start of the private enclosure for the mid
A deviation from TG’s build, I added a brace centered on the 18”. Not sure if really needed, especially with 1 1/2” cabinet sides, but didn’t think it would hurt. Also ties into closing the private space for the crossover and plate amp.
View from the front
Front view of the mid enclosure
All that’s left for woodworking is the two layers that make up the rear panel. The Maple panel is ready to go. But final Medex panel will take some time making the opening for the crossover and plate amp.
Old 10th February 2019, 08:53 AM   #76
Really amazing woodwork
i think it is a good idea with brace behind the 18" ,,i wish i have done that,,
Best Bjarne
Old 11th February 2019, 08:42 AM   #77
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
If you can see the speaker cone move...it's not hifi.
Old 11th February 2019, 12:54 PM   #78
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Well done!
Radikal aktivist AINOgradient speaker project
Old 12th February 2019, 04:42 AM   #79
Best Bjarne
Thanks for your continued interest and replies.
Adding the brace at the center of the 18” keeps the bracing consistent at +/- 10” between.
The driver shouldn’t “see” the brace as this location aligns with the actual driver brace.
Old 12th February 2019, 04:43 AM   #80
Bas and Juhazi thanks for taking the time to comment! Let me know if you think I am missing something.
Looking for thoughts on horn speaker project Tjj226 Multi-Way 29 3rd July 2018 07:00 AM
Looking for advice on adding a super tweeter to high efficiency mono speaker Josephjcole Multi-Way 54 3rd June 2017 02:23 AM
speaker building help (right forum?) & Selenium ST300SLF Super Tweeter torontotech Multi-Way 2 7th November 2012 02:49 AM
speaker project super TAD mcmahon48 Multi-Way 0 5th February 2009 06:09 AM
Recommended Super Tweeter for 206E Horn Kofi Annan Multi-Way 11 6th June 2004 05:37 AM
Copyright ©1999-2019 diyAudio
