Finally Finished!
My new T + A gear arrived just it time. Had only a couple hours to listen before I had to fly out for the week. I know it will take some time for both the gear plus the caps to settle in, but first impressions are great!
Much simpler, cleaner setup all around now. Still need to work out spikes/feet and order polished stainless steel trim rings for the Mid and Woofer.
I agree! You put it better than I could. [emoji16]007's! Stone cold killer's in a gentleman's suit! Elegant sophistication and brutally badass combined! Thank you for causing me yet another man crush on an inanimate object! ������ Glenn.
These are utterly amazing. The TL2 build is drop dead gorgeous.
Any update thoughts on the sound compared to the TL1 you built? I just read through this entire thread. Bravo for all the update. So great to read considering I'm on the brink of ordering the parts for my own TL2 build.
Would love to hear your thoughts on everything.
@Coasttocoast
Your TL-2 are gorgeous.
Did you end up getting the stainless steel rings for the drivers?
Where did you purchase them? And if you don’t mind how much did they cost?
May I see a picture? Were they hard to install?
I am just about to start gluing mine together.
I recessed both the 10 inch and the 18 inch. I had to freehand the 10 inch a little bit and my jig slipped without me noticing it for the 18 inch.
I am not sure how I’m going to smooth it out, maybe Bondo??
- Big Speaker Project, 18” + 10” + CD/horn, super tweeter
