sub woofer and mid range for 4 way horn speaker
Old 6th December 2018, 07:22 PM   #1
Best Hi End is online now Best Hi End
Default sub woofer and mid range for 4 way horn speaker
I'm building an active 4 way horn speaker and I'd appreciate if anyone could let me know whether any of the following B&C 18DS115 or 18SW100 or 18SW115 is a better performer than BMS 18N862 or FaitalPro 1800XL1800 as far as pure clean bass without distortion from 20Hz up to around 200Hz with DSP amplification or should I stick to the above mentioned BMS or Faital?
(bearing in mind that I intend to build a sealed stereo subwoofer which don't exceed the size of D-55c"m, W-55c"m, H-80-120c"m or if someone could email me a tapped/folded or other horn speaker drawings that cover the frequencies of:20-150-200Hz-I'd be grateful)
What mid range is better in this set:B&C 12PE32 or 12MH32 ?
My other planed components are tweeter-SA8535 and for compression driver B&C DCM50 .
Old 6th December 2018, 08:51 PM   #2
hottattoo is offline hottattoo  United States
Go through Bd audio site. They have horns, drivers and good ideas on designs.
BD-Design, only the best!
Good luck.
Old 7th December 2018, 03:04 AM   #3
OscarS is offline OscarS  United States
If you want low-distortion, B&C & 18 Sound are good, Ciare is better, but few beat Beyma.
sub woofer and mid range for 4 way horn speakerHide this!Advertise here!
Pair Faital PRO 3FE22 3" NEO Full Range Line Array Woofer Speaker s 16 ohm 91dB HonorPC Vendor's Bazaar 0 12th November 2018 12:12 AM
Looking to build a full range speaker...either a horn loaded or array(open baffle). ellisr63 Full Range 39 20th September 2018 03:41 AM
For Sale: Magnavox Woofer and Horn Speaker Sal Brisindi Swap Meet 6 19th June 2016 07:15 PM
2 way speaker with a folded horn woofer? bcodemz Multi-Way 11 23rd October 2015 03:27 PM
Back Loaded Horn (BLH) Full Range Speaker Build jgray Full Range 10 6th June 2011 04:25 AM
