Placing autotransformer in crossover
Old 7th December 2018, 10:50 PM   #21
EarlK is offline EarlK  Canada
Here's a good example of how JBL used to use autoformers ( back in the day ).
Placing autotransformer in crossover-autoformer_example_in-network_-png
The point is that an autoformer is also an inductor and some of the more clever designers will just build it into the overall network ( when they can ).
Notice the switched conjugate resistors ( source side of the autoformer ) working to present a consistent impedance to the preceeding capacitor.
I'm a bit surprised the OP didn't see the "reflected" impedance issue crop-up since those pics seem to be snaps of XSim ( which has an excellent impedance window ).
Old 7th December 2018, 11:47 PM   #22
Originally Posted by GM View Post
FWIW here's an ancient Altec two way autoformer schematic: http://digilander.libero.it/stevevis...N800schema.jpg
GM
GM
Placing autotransformer in crossover-n800d_schema-jpg
Must be a case of dimming eyes, but that's no autoformer, instead that's Altec's ( clever ) kludge-up in how-to-make a multiple-fixed attenuation LPad ( using resistors ).
Multiple taps on a single Ohmite variable 25W?? wirewound resistor are implemented.
Here's a thread ( over at AK ) that details the N800E ( using resistors )..
Worth noting is that the posted schematic is incomplete ( in the posted schematic the HF section wasn't referenced to ground ).
Still, it's good info if one uses it carefully.
The exposed N800E will look something like this;
Old 8th December 2018, 12:35 AM   #23
GM is offline GM  United States
GM's Avatar
The original 800D [among others] had an auto-former and that's the correct diagram AFAIK, but I can't find any pre LTV docs on-line, so not surprised that this apparently was yet another example of their extreme cost cutting demands that ultimately destroyed them.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 8th December 2018, 01:10 AM   #24
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
I have a pair of Tannoy Monitor Golds with autotransformers in the crossovers.
The Tannoys have 5 taps
The Tannoys have a single 50 ohm resistor connected to the autotransformer which is switched in the opposing direction to the tweeter.
When the HF is in the highest position the 50 R is disconnected.
I understand what the following parts of the HF circuit do but I am unclear on how the 50R effects the circuit
Copy of schematic attached, the only difference from what I have is the LF inductor is nearer to 3mH.
Old 8th December 2018, 01:35 AM   #25
When switched in, the 50 ohm resistor lowers the circuit resistance as seen by the 6.8uF cap.
It doesn't matter if it's placed in front or behind the autoformer > the 50R resistor still lowers the circuit impedance.
Placing autotransformer in crossoverHide this!Advertise here!
How unsafe is an Autotransformer? Richard Ellis Tubes / Valves 66 9th March 2010 09:34 PM
Does placing the woofer above the tweeter effect the crossover in a two-way design? wigginjs Multi-Way 3 9th March 2009 08:37 PM
building air-core crossover autotransformer montreal Multi-Way 0 22nd May 2006 03:51 AM
Autotransformer for 220v in the UK Pickledcreeky Everything Else 7 9th September 2005 06:39 PM
Rewinding an autotransformer Stocker Parts 4 15th October 2004 05:13 AM
