Placing autotransformer in crossover
Old 6th December 2018, 05:26 PM   #11
marco_gea is offline marco_gea  Italy
Originally Posted by olsond3 View Post
Help me understand this. What known electrical properties of the autoformer make it sound different and what would make those differences better? I assume it can only have more distortion than a resistor divider if undersized (saturation, hysteresis) and some frequency response variations. Resistors could have a tiny amount of inductance, some miniscule variation with heat if undersized, self noise below 100 ohms isn't going to matter.
I don't think it's a matter of the intrinsic characteristics of the autoformer vs. the series resistor, but rather of the interaction of the attenuated tweeter with the driving amplifier.
But as I said, the differences are subtle. Not worth losing sleep over them ;-)
Old 6th December 2018, 05:59 PM   #12
olsond3 is offline olsond3  United States
marco_gea: You made some claims of clearly audible differences worth understanding: 1) "Best" and 2) " an autoformer-based solution just sounds a little bit better, IMHO: more dynamic, essentially, and possibly subjectively slightly more "refined", for whatever that may be worth."
If it comes down to interaction with the amplifier, I can see that could happen if it presented a higher impedance to the amplifier. Amplifiers typically have lower distortion when used with higher impedance loads (Doug Self). So the transformer when used to attenuate should present a higher impedance, unless you place an 8 ohm resistor at the input to the autotransformer, as suggested, then the load to the amplifier will look identical. I'm not seeing the mechanism for audible improvement using well understood electrical properties.
Old 6th December 2018, 06:26 PM   #13
alayn91 is offline alayn91  France
alayn91's Avatar
Hello,
And, where can this kind of auto-transformer be found ??
Old 6th December 2018, 08:41 PM   #14
hottattoo is offline hottattoo  United States
Send an email to Dave Slagle (Emia audio ) since he can custom wind autoformers / transformers to your specs. Good luck.
Old 6th December 2018, 08:46 PM   #15
Almost forgot, Fostex makes a transformer attenuator ( model R100t ) which may also work.
Old 7th December 2018, 05:55 AM   #16
GM is offline GM  United States
GM's Avatar
FWIW: intact audio
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 7th December 2018, 10:59 AM   #17
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
If these advantages of an autoformer over a L-pad or a simple resistor in series can be measured or verified otherwise, the explanation might be that the tweeter sees a decreased source impedance from an autoformer, while the impedance usually is increased by resistors. No need to worry about saturation effects in the tweeter section in my opinion, as the signal Level isn't that large here ans a transformer may cope with the HF range much easier.
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 7th December 2018, 01:07 PM   #18
mboxler is offline mboxler  United States
If the tweeter is 8 ohm and draws no more than 10 watts...
ALK Engineering
Click on Klipsch Loudspeaker Upgrades, then Tweeter Attenuators.
Old 7th December 2018, 05:07 PM   #19
Default Got it. Higher impedance presented to amplifier.
Originally Posted by GM View Post
FWIW: intact audio
GM
Thanks for the references. So it looks like the benefit comes from putting it before the crossover so that it can present a higher impedance to the amplifier, resulting in lower amplifier output stage distortion. If I keep reading, one of these days I may actually understand what's going on!
Old 7th December 2018, 10:21 PM   #20
Brinkman is online now Brinkman  United States
Another source for autoformers is Bob Crites: Autotransformers | Critesspeakers.com
Mast_mutter on the auction website is yet another source
Placing autotransformer in crossoverHide this!Advertise here!
How unsafe is an Autotransformer? Richard Ellis Tubes / Valves 66 9th March 2010 09:34 PM
Does placing the woofer above the tweeter effect the crossover in a two-way design? wigginjs Multi-Way 3 9th March 2009 08:37 PM
building air-core crossover autotransformer montreal Multi-Way 0 22nd May 2006 03:51 AM
Autotransformer for 220v in the UK Pickledcreeky Everything Else 7 9th September 2005 06:39 PM
Rewinding an autotransformer Stocker Parts 4 15th October 2004 05:13 AM
